Results 11 to 20 of 21
- 52,731
June 11th, 2020 05:40 PM #11i read someone explain it.
because of its design construction and choice of materials,
when it gets hot, the material expands and chokes the moving part, freezing it in its tracks.
fuel stops getting pumped.
June 11th, 2020 05:48 PM #12
Here we go.
Honda Cars Philippines, Inc. has finally pinpointed 10,136 units of 2018-2019 Accord, BR-V, Mobilio, City, Civic, Jazz, HR-V, and CR-V models that will require a recall due to faulty pumps. These units have fuel pumps that contain defective impellers that can inflate. This can cause the pump from rotating, causing the engine to stall or fail to start.
This is a similar recall done by Mitsubishi Motor Philippines on the Xpander.
From carguide
- 52,731
June 11th, 2020 07:00 PM #13toyota.. mitsu.. honda..
if pumping fuel is all the fuel pump does,
it should be a simple thing for the car manufacturer to get another pump that has good track record, and mount it on their pump holders.
June 13th, 2020 08:40 AM #14
How come amaze is not included in the list? does it use different type of fuel pump? I check with honda site and input my 17 alpha numeric chassis number and turned out 0 results.
- 52,731
June 13th, 2020 08:55 AM #15
June 13th, 2020 08:58 AM #16
June 13th, 2020 10:06 AM #17
June 13th, 2020 10:21 AM #18
Honda Cars Philippines › Recall input your VIN no need to bring the car physically
Hanggang June 30 na lang.
Blessing in disguise, buti pala hindi ko doon pinasok oto ko for body repair. Pero tatapusin pa din naman siguro nila noh lahat ng received na for services?
June 13th, 2020 10:23 AM #19
June 13th, 2020 10:27 AM #20
Yup. Hindi ako nag stay dun sa AC na lounge, andun lang ako sa open area wala gaano tao. Lahat andun naka aircon. Pababa baba din kasi ako umuusyoso sa trabaho.
May seat markings dun sa lounge pero kahit na feeling ko kulob sila doon hehe
In my car idle on coldstart was 2k high need 2 to3 mins to be restarted the engine to get the...
high idle RPM at engine start
