Results 11 to 20 of 29
- 52,700
May 21st, 2019 07:00 PM #13
I think the best comparison here for 4at vs cvt fc is the 3rd gen vios.
Earlier batches had 4at, while latter batches have cvt.
- 52,700
May 21st, 2019 07:12 PM #14
May 21st, 2019 07:32 PM #15
- May 2017
- 2,099
May 21st, 2019 08:01 PM #16
Yup, yan ang narinig ko, sabi pa daw ni Scott Kilmer sa Youtube, CVTs have even the potential to even surpass manual transmissions in terms of fuel efficiency because computers are the ones who are consistently calculating the appropriate correct speed based on the driver's behavior so as to come out with the most efficient use of fuel economy. So say goodbye to manual transmissions hehe
- May 2014
- 1,318
May 21st, 2019 08:57 PM #17It may not be written in the manual, but i rather not rrisk running the transmission while there could be an error in the computer box after battery removal (without running off the alternator).
Im just saying what i do to avoid needing a cvt reset.
I also own a sylphy cvt. When nissan serviced the sylphy, they removed the battery over the course of repair work (i posted this in the thread for sylphy).
When i got the car back, the transmission was behaving differently. I brought it back for a reset. Nissan doesnt have the same like honda. So they installed the latest firmware they had on hand for the cvt. Basically equivalent to a reset.
The transmissiom behaved the same after it as well.
So, you could see it as anecdotal. But that has been my personal experience with cvts and i would rather not risk it.
- Feb 2014
- 2,536
May 21st, 2019 10:29 PM #18
May 21st, 2019 11:32 PM #19
Personally, my main beef with CVTs is the long-term durability because I tend to keep my cars until they either fall apart or quit running (usually 13-15 years). Otherwise, I find the CVT great when using cruise control on road trips. Perhaps, I'm wrong. But, the CVT is always at the most optimal/efficient setting of the RPM range which is not the case with conventional AT. An AT is prone to gear hunting during a climb with roughness and speed loss/compensation. With a CVT, assuming a climb the CVT can handle, the speed remained constant with smoother adjustments. It really surprised me (in a good way) the first time I encountered it.
- Feb 2014
- 2,536
May 21st, 2019 11:34 PM #20
