Results 761 to 770 of 1220
November 24th, 2015 09:23 AM #761
January 12th, 2016 10:01 PM #762
Planning to get a used 2007 crv 4x2. What are the common issues i need to look out for?
Sent from my C6802 using Tapatalk
- Aug 2015
- 76
January 12th, 2016 11:57 PM #763All of the generations tend to be reliable, although, the 2007 model can have some issues. I suggest you check the power door locks, air-conditioning, and the automatic driver's window for any possible malfunctions. You should also check the tyres, since they tend to wear out quickly. If you have taken / plan on taking it on a test drive, check for any rattling sounds or loose parts.
Other than that, try to look at the maintenance records to see if it was well taken care of in the past. Should that be the case, the car should not have any major problems.
January 13th, 2016 08:20 AM #764
Timing chain na ba ang 2007 crv? 2.0
- Aug 2015
- 76
January 13th, 2016 09:53 PM #765
January 13th, 2016 09:56 PM #766
Got my crv earlier today, everything was functioning well. The owner misplaced the sparekey. Planning to have it duplicated. Can i start the engine using duplicate key from the mall?
- 52,731
January 14th, 2016 12:31 AM #767
January 15th, 2016 09:52 PM #768
Question regarding 2007 crv electric power steering (EPS)
While i was parallel parking my crv, the steering became harder to steer and the eps light comes on and off. Have you guys experienced this on your crv? Should i be worried?
- 22
February 4th, 2016 01:25 AM #769
- Jan 2016
- 25
February 4th, 2016 05:43 AM #770
high idle RPM at engine start
