Results 1 to 7 of 7
- Sep 2009
- 3
September 18th, 2009 07:13 PM #1Has anyone experienced noticing blinking "D" on their CRV? Any solution for this?
- May 2006
- 1,668
September 18th, 2009 07:50 PM #2Overheated Transmission Fluid. Check Fluid at once. Drain and Refill.
- Aug 2009
- 56
September 19th, 2009 11:42 PM #3
- May 2006
- 1,668
September 20th, 2009 12:30 AM #4Yup. Read ur car's manual. Its written there.
Blinking D means your transmission has a problem, pull over.
Problems might be
1. Overheating (no fluid/dirty fluid/lacking fluid) <- will be fixed once you drain and refill the fluid
2. Transmission computer issues <- Casa na to.
Using the car with Blinking D for long periods of time will result in a broken transmission.
Mahal ang transmission.
Worse comes to worse, tranny should be pulled down and check for gear wear and tear.
- Aug 2008
- 28
- Sep 2009
- 6
September 24th, 2009 03:48 PM #6Blinking "D" is for automatic transmissions located near the speedometer.
I had the same problem early this year. The mechanic said madumi daw yung solonoid which i had cleaned and it went away. Unfortunately CRV's and Accords are known for transmission problems. They have the same type of transmission, I had first hand experience for both cars 02 Accord & 02 CRV
- Aug 2008
- 28
September 24th, 2009 04:19 PM #7thanks for the info sir... yung sa amin po crv manual.. pero nag ka problem din ung transmission nya... mahirap mag downshift... ayun.. baba yung trans. assembly..
got to check one out at sm san fernando today. rear visibility is very poor :twak2: and as typical...
2020 Kia Sonet
