Results 431 to 440 of 1050
June 18th, 2003 04:46 PM #431
double contact din sya... mas maganda sana kung ginawa nya na iilaw pag aapak nalang ng preno.
- 91
June 19th, 2003 10:18 AM #432double contact din sya... mas maganda sana kung ginawa nya na iilaw pag aapak nalang ng preno.
From what I know, 1 lang dapat ang rear fog, normally found on the left side of a car and is always lit when you turn on the front fog lights. They're usually as bright as the brake light when the double contact is engaged. Locally ang alam kong me rear foglight na stock would be the RAV4. If I'm not mistaken, you can find it by the left side of the rear spare tire of the RAV.
June 19th, 2003 06:09 PM #433
check out the CR-V HCP thread and ask veegee how he did it DIY style in his Gen2 V. I think he used a ceramic socket and used a double contact bulb.
- 91
June 19th, 2003 07:53 PM #434check out the CR-V HCP thread and ask veegee how he did it DIY style in his Gen2 V. I think he used a ceramic socket and used a double contact bulb.
Clarification lang. Does this pertain to the stock 3rd brake light of the gen 2 (similar to the gen 1 mounted inside the rear window), or the rear foglight?
Tsikot Member Rank 4
- 1,842
- 91
June 21st, 2003 05:41 PM #437bacon,
yung rear fog yung DIY
Just the same, thanks for the info.
BTW, Sups, I tried emailing Weisbock (Fastlane, of HCP) but I received a failure in transmission advisory (errors, I think). Would you happen to know how I can get in touch with him or his shop?
- 91
June 22nd, 2003 04:40 PM #439san makakabili ng rear foglights?!?
peace!!
- Mar 2003
- 81
June 22nd, 2003 04:48 PM #440hey guys... meron ba kayong alam headlight protectors? san kaya makakabili nito? thanks
high idle RPM at engine start
