Results 1 to 10 of 10
- Aug 2007
- 5
August 2nd, 2007 03:05 PM #1[SIZE=4]hi everyone
[/SIZE]
[SIZE=4]please give me your comments, suggestions or experiences regarding lowering the 2003 crv using lowering springs. does it improve the ride? what springs do you recommend?[/SIZE]
[SIZE=4]THANKS (^.^) [/SIZE]
August 2nd, 2007 03:18 PM #2
lowering (almost any car) will make the ride worse, since there will be less vertical play to dampen shocks
- Aug 2007
- 5
August 3rd, 2007 10:48 AM #3thanks for your reply
but you see, my crv is the 10 seater version and i heard that lowering springs do soften the ride since the current springs are to accommodate 10 people of load.
pls enlighten me ^^; thanks
August 3rd, 2007 10:57 AM #4
if you want to make your ride softer, get softer springs, lowering springs tend to be more stiff than OEM springs, so stiffer springs = harsher ride.
If you get softer springs, your cars handling will sufer because there is more bodyroll but you'll get a more comfy ride, Get stiffer springs, handling will improve, ride quality will suffer so there is a trade off.
August 3rd, 2007 02:58 PM #5
Actually, lowering springs would be less stiff than the 10-seater springs in the rear, while stiffer in front. But you shouldn't mix and match, as that would upset the stance of your vehicle.
It's the same case with Fortuner lowering springs... they're less stiff in the rear because the stock springs are extremely heavy duty.
Just get the entire rear set for the non-10-seater version... that'll cure your problem.
- Aug 2007
- 5
August 4th, 2007 10:39 PM #6[SIZE=3]thank you for your replies guys
[/SIZE]
[SIZE=3]so if i buy the 5-seater springs set, that would already improve the ride? do i need to change anything else other than the spring to improve the ride or will the springs alone do?[/SIZE]
[SIZE=3]THANKS AGAIN ! [/SIZE]
August 5th, 2007 12:35 PM #8
August 6th, 2007 06:02 PM #9
i changed my 2002 crv to original us version coil springs, ride went better way better
- Aug 2007
- 5
August 6th, 2007 08:40 PM #10[SIZE=3]thanks again for the replies guys !
[/SIZE]
[SIZE=3]where did you get your US version original coil springs? from honda? and how much was it? [/SIZE]
[SIZE=3]T H A N K Y O U ! ![/SIZE]
Anong Chinese brand na ba ang available sa market? Yung Leoch brand may nakita na ko post sa FB....
