Results 21 to 30 of 34
September 5th, 2009 07:51 AM #21
fan motor axiliary...ang dami nyan sa auto supply/banawe dont worry bout it. prepare maybe 1500 for a nice surplus, a bit higher pag b/new.
hindi ba kumayod sa condenser yung fan blades?
September 5th, 2009 04:33 PM #22
* ans_lim168 thanks sir....
* voltscastillo...nope Sir hindi sya nakayod sa condenser. Free pa din yung rotation nya yung nga lang kung papansinin closer hindi align kung baga may wiggle yung fan.
- Aug 2008
- 28
September 24th, 2009 04:14 PM #23tanong ko lang din.. crv gen1 din akin ... may grinding sound din.. pero tuwing umaga lang sya.. (unang start) tapos mga 5-20 seconds lang naman.. ano kaya yun mga bossing??? suspect ko din ung fan.. pero kung sakali ano kaya maganda gawin (repair)
September 24th, 2009 07:10 PM #24
- Jun 2009
- 15
October 12th, 2009 03:37 PM #25
- Jun 2009
- 15
October 12th, 2009 03:45 PM #26Need advise/feedback, i have difficulty starting my crv 1st gen when the engine is hot. after turning off the engine, i need to have the engine cool off ng mga 5mins before it will start. read in some auto write-ups that sometimes this happens due to vaporization of fuel. i was also told that its because of the heating up of the alternator. i am more inclined to believe that the problem is electrical. i just had the battery changed (2mos ago) also had 1 of the battery terminal changed because umiinit. would appreciate for a feedback and/or advice. TIA
- Jun 2009
- 15
October 12th, 2009 04:05 PM #27bought my CRV 1st gen about 4 months ago. the problems i encountered n repairs i made are:
1. clutch fluid leaking - replaced repair kit (up and down) also replaced a hose, beacuse there was a leak in 1 of the hose.
2. clunking sound when tight turn - replaced differential fluid
3. clunking sound sa fan/radiator area - replaced aux fan, malakas na kasi play n tumatama sa radiator
4. I also replaced transmission fluid, mas smoother ung takbo
5. hard starting - replaced battery and 1 of the battery terminal. umiinit daw sabi ng electrician
ung lang natandaan ko,
- Apr 2007
- 3
October 15th, 2009 11:45 PM #28mga bro,
if i want to upgrade my transmission (honda crv 99 with overdrive) meron ba kayong mairerecomend para mas mabilis yung crv, ty.
October 17th, 2009 02:22 PM #29
Good day. Ned help.
I noticed on my CRV 99 model, hindi tumatakbo yung Aux fan on the driver side but the other fan is ok naman smooth ang takbo. Before, umiingay ito na parang grinding sounds when I checked it naglalaro yung fan mismo pero hindi naman tumtama sa radiator. This time kaya nagtaka ako bigla nawala yung grinding sound yung pala hindi na sya tumatakbo. Kailangan na ba ng replacement ng aux fan? how much po ba ito at saan makakakita. Sa mga surplasan ba meron nito?
Another issues is biglang namamatay ang auto while running 3x ko na ito na experience buti na lang dito lang sa area namin at hindi sa highway or expressway. Matic po ang CRV ko once mamatay totally ititigil ka sa daan. OK pa naman ang battery one click start na agad. Ang assumption ko is sa KEY MECHANISM may play while in acc or on slot. Hinanap ko ito nilarolaro ko yung key while the engine is running. Hindi ko tine-turn off slot namamatay engine. Dito lang kaya ang problema or meron pa ka yong ibang inputs or thought.
Please help me. I need some advise.
I just bought this 2nd hand CRV'99 model 3 months ago. TIA
October 17th, 2009 02:33 PM #30
Mga sir need your advise and inputs.
Meron akong naririnig na "Ik ik ik" or metal to metal sounds sa ilalaim while running the car straight in 10 to 30kms pero once increase the speed nawala na yung "ik ik" or metal to meatl sounds. Saan po ba ito differential issues? ANo po kailangan ipachek-up or to repair?
TIA
high idle RPM at engine start
