Results 1 to 10 of 10
    Apr 2011
    it takes a long long time for the ENGINE CHECK LIGHT to turn off.
    only when its off, will the engine start...
    anyone can point me in the right direction.
    thanks in advance...
    Jul 2011
    how long is your long long time?
    basically, ganyan naman talaga, wait for a few seconds before engine light is off and start the engine.
    well, our honda cars does the same.
    toyota lang ang alam kong walang patayan ng engine light.
    Apr 2011
    Quote Originally Posted by 7138 View Post
    more or less mga 5mins before the light goes off... the engine wount start also, until the light goes off...
    replacing all electrolytic capacitors on the ECU might help ... with age, those capacitors will dry up inside and could cause the symptom above
    Jun 2017
    Mga paps may problem din ako sa ESI ko eh ayaw nya magstart D15B PO8 head nya, puro redondo lng siya tpos ayaw magtuloy nung pinadiagnose ko code 8 (TDC) code 9 (CYP) and code 10 (IAT) ang naread na error. ano po kaya dapat ko gawin or palitan? salamat mga paps
    ^ main relay mo na check na bro?
    Jun 2017
    boss aling main relay?
    mas maigi si eric the car guy na lang magexplain kasi hindi naman ako expert
    hth
    Jun 2017
    hth
    Salamat paps atleast may idea na ko kung anong dapat ko ipacheck. kinakabahan kasi ako kasi baka palitin ang distributor ko o kaya ECU mejo malaki gastos yun.
    Thnks paps
    Jun 2017
    Quote Originally Posted by agong1329 View Post
    Thnks paps
    Mga Paps hihingi po sana ako ng info sa inyo... tatanong ko lang po sana kung magkno ang range ng price ng PO8 computer box para sa ESI natin?
    palitin na po kasi ang box ko eh di ko magamit oto ko... thanks in advance mga paps
Honda Civic ESI starting problem
