Results 11 to 20 of 34
- Oct 2009
- 2,271
December 9th, 2014 02:43 PM #11
December 9th, 2014 08:25 PM #12
Dinala ko honda casa pero wala sila binanggit sa fuel pump saka sa fuel filter eh....anyway will cconsider din yan pag punta ko kay mel cabasa.....
Mahirap kse kung lahat ng irerecommend ng casa ay papalitan at gagastos tapos in the end ituturo din transmission pala yan ang masakit....
December 9th, 2014 10:55 PM #14
Yes sir weszt sana nga pero dapat di trial and error kse magastos talaga pag di agad nalaman kung saan pinag mulan ng problema.....waiting ako sa ibang inputs pa baka may nakaexperience sa mga naka CVT para naman malaman kung ano gagawin agad para di na lumaki pa gastos.....ok lang kse na gumastos pero sure kesa gagastos tapos di pa pala yun marerepair kse nga trial and error ang dating.....anyway si wezz wezz alam ko 2times na ata nag palit tranny nya sana makausap ko din sya.....
December 28th, 2014 12:51 AM #15
- Jul 2014
- 13
December 28th, 2014 05:38 AM #16i vote for the coilpacks. it started to get weak at around 60tkm, causing a random misfire. bawasan mu yung gap ng sparkplug gawing mung 0.034 inch. tapos observe mu. pag nawala idle fluctuation. yun na yung problem coilpack. kung baga ndi continuous yung spark ng plug. kya nagkakaroon ng hesitation. possible din pla yun egr valve mu dahil nararamdaman mu sya at 60kph. ganyan din problema ng jazz ko noon vtec1.5cvt. palitan muna agad yun pcvhose khit yung ordinary na fuel hose. kase breather yan ng makina. otherwise mag kk langis yung air filter mu and eventually mag kka oil leak ka sa mga gasket. na pipipi tlaga yung hose or 'colapsed' dahil dun sa engine cover at init ng makina. magkano nga pla bili mu sa pcv valve at saan ka nakabili kasama yung rubber grommet? thanks.
- Jul 2012
- 329
December 28th, 2014 04:35 PM #17san ba maganda buy coil packs? need balahat palitan or yung may sira lang? balita ko mahal isa nyan..
- Jul 2014
- 13
December 28th, 2014 06:36 PM #18sa casa ako bumili 4,200 isa hitatchi brand lng ang OEM. meron ding other brands na tig 1500 pero iwasan mu yun. kapag tinetest buo sya. wala din error codes. pero nung pinalitan ko coil pack. tapos ang juddering, hesitation, misfire, idle fluctuation etc. running very smooth now. mag basa ka din ng other forums like 'fit freak' para makita other international problems ng jazz/city and their solutions. i suggest maghanap ka muna ng kaibigan na same car at maki swap ka muna ng coil and then test drive. pag naayos ska ka bumili. kung sa cvt tlaga problem mu. bago na rin ang design ng starter clutch mas malaki mga clutch plates. kaya dapat latest design ang mabili mu just in case.
December 29th, 2014 10:48 PM #19
December 29th, 2014 10:49 PM #20
It helps that the three generations of the leaf share the same battery formfactor and can use the...
2021 Nissan Leaf
