Results 881 to 890 of 923
July 4th, 2021 12:12 AM #881
- 52,731
July 4th, 2021 06:49 AM #883
the lower arm which should be holding the ball joint snapped off.
you can see the balljoint still attached to the knuckle. if you're looking for the stab link, its still on the stabilizer bar.
here's a lower arm with the ball joint still attached. photo
ito ba hanap mo doc? parang weld lng yun sa brv.
- 52,731
July 4th, 2021 08:49 AM #884
- Jun 2011
- 1,080
July 4th, 2021 01:28 PM #885Lagot ako dito, kasi parehas din suspension sa Mobilio.
Iyong assembly/mounting niya mukhang naka machine press.
Front Lower Arm Right Honda BRV 1.5 br-v 216-22 | Shopee Malaysia
2 FRONT LOWER BALL JOINT FOR HONDA BR-V 217-22 | eBay
Doon sa 2nd picture mukhang putol ang balljoint assembly. Doon sa knuckle side. Iyong ball assembly naiwan sa arm. Boot at bolt ang naiwan sa knuckle. Labas ball joint part defect. (?)
July 4th, 2021 01:43 PM #886
- Jun 2011
- 1,080
July 4th, 2021 08:30 PM #887
- Aug 2021
- 1
August 2nd, 2021 08:12 PM #888Honda Brv 2020 prestige/1yr 7months/12k odo
May nakita ako sa serpentine belt na ganyan, hindi sya tastas eh, parang sobrang threads galing sa loob. Nagtanong ako sa group ng brv, may mga nagsabing normal daw meron ding nagsabing palitan ko na daw. May isang nagsabing halos lahat daw ng kotse ngayon may ganyan.
Normal po ba talaga yan?
- Jan 2008
- 4,726
- Jun 2011
- 1,080
January 5th, 2022 05:21 PM #890Jan 2022 promo as per Carguide article.
70K discount sa BR-V V. Okay din. Nag uubos na siguro ng stocks. Last chance na din para sa fold and tumble na 3rd row. Para tall trunk space na low load height.
high idle RPM at engine start
