Results 1 to 3 of 3
- Feb 2008
- 31
August 26th, 2008 10:20 PM #1Ask ko lang po sana kung alam nyo po yung PSI specs ng RAD CAP ng Accord '94? Parati po kasi ako nauubusan ng coolant eh. Posible po kayang mali yung rad cap ko? Meron pong nakasulat na 0.9 dun sa current na cap nya eh. Or could there be other cause kung bat nauubos ung coolant ko? TIA!
August 27th, 2008 09:50 AM #3
The ratings on radiator caps are in bar, not PSI. 1 bar is equal to 14 PSI.
Most likely you've used the wrong radiator cap. Honda radiators usually ask for caps with much higher pressure ratings. The most common ones I've seen used on Hondas are rated at 1.1 bar.
If you can score Mugen radiator caps, they're rated even higher at 1.35 bar---still good for everyday driving.
When does that happen? 1. During starting? 2. While the vehicle is idling/running?
ALTERNATOR. Repair or replace?
