Results 11 to 20 of 44
January 6th, 2009 03:06 AM #11
Try changing tranny filter and fluid first. It might be the linkage also needs adjustment, check that too. If it cannot be adjusted, then its stretched too much, and needs to replaced. Good luck
- Jun 2004
- 1,311
January 6th, 2009 10:31 AM #13
yung corolla big body 94 model dito sa amin ang problem is pag malamig ang engine ayaw kumagat ng reverse need pa ng 3 to 5 min para kumagat sabi ng isang mechanic replace matic trans na daw? sabi ng isang mechanic try to replace atf & filter yun tuwang tuwa at naging maayos ang trans nya smooth shifting pa
- Nov 2008
- 24
- Nov 2008
- 24
January 6th, 2009 10:45 AM #15
- Nov 2008
- 24
January 6th, 2009 10:47 AM #16
- Nov 2008
- 24
January 6th, 2009 10:54 AM #17
- Nov 2008
- 24
January 6th, 2009 10:59 AM #18may kilalala ba kayong mekaniko na magaling sa pag overhaul ng transmission, honda expert?...im thingking kasi na overhaul na lang, para mas makakatipid..kasi mahal ata kapag bibili ako ng replacement.
what do you think guys? this is my first car kasi, first time buyer....tagal ko pinag ipunan, pero naisahan naman ako.
kung may kilala kayo mekaniko for automatic trasmission, yung hindi nananaga ng client.at mapagkakatiwalaan..
any reccomendation mga bro?
January 6th, 2009 11:08 AM #20
high idle RPM at engine start
