Results 11 to 13 of 13
- Jan 2008
- 6
April 29th, 2008 08:23 AM #11
April 29th, 2008 08:38 AM #12
Dante,
Kung hindi naman daw dinadala sa track yung kotse, okey lang daw kahit walang hub ring.
Pero gusto natin makasigurado... ;) Better to use the spigots as designed instead of risking the studs shearing off the hub.
The process will take a day pala, not 2 hours. It will depend on whether Autoplus has material at hand for the rings or not. You can just bring your car there and get the inner and outer diameters measured, then drive off while they machine the rings.
For more details you can try calling them up at 7260399 or 7263066. Good luck bro
- Jun 2004
- 1,311
June 13th, 2008 02:14 AM #13sure na gumagawa yung sa rota nung hub ring? malapit lang kasi ako sa factory ng rota, baka dumaan ako dun mamaya...
Somewhat expected from a rushed car from a first time carmaker
Xiaomi E-Car
