Results 41 to 46 of 46
September 1st, 2010 12:18 AM #41
September 19th, 2010 08:27 PM #42
Hindi ko muna pinakabit yung temp gauge (no overheat problems yet) but I did have the vacuum and volt gauge installed by Jemson kanina.
Here are photos and I have vacuum gauge questions on this other thread if you guys would like to help: http://tsikot.yehey.com/forums/showt...56#post1563956
T-fitting for vacuum gauge:
- May 2005
- 234
November 1st, 2010 04:00 AM #44
Maizone in Banawe at Php200/pod
December 11th, 2010 10:29 PM #45
sir otep,
kung pwede lang eh sana maiprovide mo yung wiring/schematic diagram for the illumination of the gages (bulb).
my pickup has a separate switch (located at the ground side not on the hot side) for the clearance/park lights eh i'm planning na sa circuit na yun ko itap yung illumination.
sa tingin ko naman e kakayanin naman yung load tutal 10A pa lang ang pinkamababang fuse rating na nakita ko sa dash. do i really need to add a fuse for the illumination?
i think yung circuit brand na mech'l temp gage na nabili ko for P480 e around 3 watts ata yung power so that would be less than an ampere drawn from the formula power = current x voltage.
ginawan ko na lang ng semi frame yung gage ko from the various metal junks around the house.
nagpafabricate na rin ako ng hose for the sensing bulb plus magddrill pako ng 18mm (anlaki no) for the tube sa firewall dahil masikip na lahat ng available holes.
pwede pa yung hole for the A/C pero i think maaapektuhan yung reading dahil gas-filled ata yung sensing tube e.
TIA
- Jul 2012
- 329
July 31st, 2015 09:57 PM #46sir yung mga obd2 adapter na kinakabit sa port tapos pair via bluetooth pwed measure temp.
Yes, i do think so. Since it's based on the 4th-gen delica/space gear, which in turn shares some of...
Mitsubishi Philippines
