Results 1 to 13 of 13
    Sep 2012
    mga sir... patulong sa tsikot ko... pag ON ung ac, nagddrop ung idle.. and pag asa 1500rpm siguradong' magchchoke sya..
    Oct 2009
    try mo muna pa timing ung kotse mo baka kulang sa timing kaya pag nagka roon ng load ang makina bumabagsak ung rpm.
    Jan 2013
    Quote Originally Posted by Brykilig View Post
    Same problem ng ek ko, Replace map sensor, adjust iacv, troubleshoot and change servo assembly. Dapat mascan din ecu may check engine sa dash board
    Aug 2010
    Quote Originally Posted by aragon58 View Post
    magkano mag palit ng map sensor. ganun din ung problem ko sa akin honda city 97. thanks.
    Sam problem sa accord 95 ko servo daw ang problema... magkano po kaya ito at saan maganda bumili.. thanks
    Same as my problem sa accord 95 ko servo daw ang problema... magkano po kaya ito at saan maganda bumili.. thanks
    Mar 2018
    Quote Originally Posted by sparco88 View Post
    Sir, same problem din ako sa honda city 97 ko.. hingi lng sana ako tips sayo kung panong ginawa mo to fix the prob.. salamat
    Aug 2015
    magkano po kaya
    san mas ok bumili
    May 2012
    Mine too! When warm and ac off it idles at 600-700 but when the ac is on it drops to 500. IACV, TB has been cleaned. FITV has been adjusted and cleaned also. Saan po yun area ng servo?
    Dec 2013
    Quote Originally Posted by Alfrance05 View Post
    Wala pong "servo" ang Honda Civic 92-00. The servo that most shade tree mechanics refer to is the IAC valve.
    IACV ang tawag dyan sa Honda, hindi servo. Linis lang ang katapat nyan. Isabay mo na rin linis ng throttle body
    Mar 2018
    hello guys newbie here hehe just need 5 replies lol sorry for the disturbance
    Quote Originally Posted by Sailar09 View Post
    You need 5 meaningful replies, not spam.
    The point of the 5-post requirement is for you to search the forums first if what you want to post about has been discussed already before.
    90% of the time, there is already an existing thread where your query can be answered without resorting to a new thread.
help! honda esi servo..
