Results 11 to 13 of 13
- Oct 2008
- 10
August 3rd, 2009 10:28 AM #11sir galactus,
i have the same problem with my 94 esi. did the main terminal solve your problem? yung honda ko di pa naman namamatay while on the road. and hirap lang talaga mag start.
i had it tuned up, checked distributtor, changed the ect, diagnosed the ecu; pero ganun pa din.
il have the main terminal checked within the week, sana sir eto na ang solusyon sa problema ko.
hope that you give some inputs also.
thanks
hammerofgod
August 3rd, 2009 11:24 AM #12
Actually, in my case, ignition coil pala ang problema, HINDI ang main relay. So, napagastos lang ako at napunta sa wala, hehehe.
Madami kasi causes ang hard starting, e.g. fuel pump, sparkplugs, starter, starter solenoid, etc. Yung main relay, usually pumapalya yan pag mainit ang panahon (nakabilad yung kotse sa araw) or if you try to restart the car after a long drive (kunyari pumunta sa 7-11 to buy something, tapos pagbalik mo sa kotse, ayaw ng mag-start).
Wait ka pa ng ibang feedbacks, and it would be better siguro if you could post in detail yung symptoms at kung ano na ang nagawa mo, para ma-diagnose ng mabuti nung ibang posters.
August 4th, 2009 10:21 AM #13
Xiaomi E-Car
