Page 2 of 2 FirstFirst 12
Results 21 to 40 of 167
    Jul 2012
    Quote Originally Posted by wezz_zzew View Post
    Nashimoto nagreply na pala ako sa PM mo. CVT ko na surplus buhay pa din hanggang ngayon.
    Basta pag nagpalit na kayo, wag nyo na gamitin yung 7 speed mode. I know masarap siya gamitin kasi "parang" mas malakas hatak, pero ang totoo dun, malakas ang rev tapos di mo minsan namamalayan nasa red line na pala rpm mo.
    I may be stupid, but I am not a fool.
    thanks sa reply bro.. appreciate your inputs. sakit sa ulo ng CVT ng honda.. sobra na stress level ko. payat na nga ako.. lalo pko pumapayat kaka isip.
    Dec 2007
    we almost had the same experience with my brothers jazz gd. rried to change cvt couple of times and we even had it for dialysis. wala din nangyari at bumabalik problem. ended up getting a surplus tranny at isahaya banawe. dun narin install.
    Jul 2012
    just used my car recently kaht hindi pa napapalitan trany.. 4x times tumirik! nung una ok pa.. pero nung traffik dun ko napansin na nagloloko nnmn sya from idle and stop and go. nag blink nnman yung "D" and check engine light is on. katakot.. buti umaandar pa after restarting the car!
    Oct 2009
    Sa 2010 wala pa namang issurng ganito?
    Aug 2004
    Quote Originally Posted by harold13 View Post
    2010 Honda City sedans have a completely different automatic transmission. It's a standard five-gear automatic with torque converter. The older models were continuously variable transmissions with a starter clutch instead of a torque converter. 2014 and up Honda City sedans use a CVT, also, but with a torque converter for better durability.
    Jul 2012
    anu diff ba ng torque converter sa starter clutch at bakit honda decided to use the starter clutch sa cvt nila? dami tuloy sumasakit ulo ngaun.
    Jul 2014
    marami kasing power loss sa torque converter, kaya gumamit sila ng starter clutch para sa fuel economy. 'engine misfire' yung symptom na parang ayaw umandar saglit . maraming nalilito sa jerking at misfire. common problem yung misfire sa jazz at ang cause ay coilpack or valves clearance. madalas transmission agad akala nila sira. sa banaue nasa 13k at cvt transmission kasama ang installation 2mo. warranty. pag dating naman sa coilpack nasa 4200 ang isa hitatchi ang brand ng original. yung mga local nasa 1500 pero napakadaling masira. binago na ang design ng coilpack dahil sa common issue na misfire. kya make sure mabili mu yung bagong design na OEM. try mu remove negative terminal ng battery for 15mins. then install and drive and observe.
    Jul 2012
    the number of coilpacks depends on the number of spark plugs? tama ba? yung sakin umingay sasakyan ko after start na parang nagkakaskasang bakal kpg idle. sabi ng tito ko parang may crack na yung ignition coil so nilagyan nya ng tape.. ayun tumahimik pero evident parin yung issue ng transmission ko. everytime ramdam ko na "pagod" na yung oto or lets say mahabang byahe na mabilis then bigla stop like sa toll or traffic ayun ilaw na check engine then blink na yung "D".
    I still drive the car today pero shorts trips nlng tlga and iwas traffic.. ramdam ko na hirap na and tranny ko at may times na may "kkkrggg" ako na ririnig pag nag gagas to accelerate. ipon mode pa. hopefully next year mapalitan ko na CVT ko.
    Nov 2014
    Quote Originally Posted by albertianss View Post
    +1 pati fuel filter din pacheck same as mine jerking sya dati akala ko tranny na yun pala dumi sobra fuel filter di ata nag papalit ng filter dati may ari kakabili ko lang kse nun otto ko last november at naramdaman ko jerking at RPM fluctuation parang sliding na....so far laki improvement nun nag palit ako fuel filter at nilagyan ko fuel injector cleaner para malinis injectors at di mag misfire....
    Jul 2012
    i tried removing negative ng batt for 15mins.. laki ng improvement from idle.. lakas hatak unlike before hindi agad andar. bakit? anu ngyari nung inalis battery saglit?
    Nov 2014
    TAMA ito I agree na all jerking ay CVT na kagad ang verdict ng iba pero it could be misfire lang or kulang sa supply ng fuel dahil barado na dumi ng fuel filter or may water sa fuel pwede din so better check it out talaga maigi bago mag decide to replace a certain parts so be carefull during assessment nyo....ako muntik na mag palit ng transmission at fuel pump at coil packs na ang estimate ay nasa 20k petot plus so mali pala dami pa pala pwede panggalingan ng jerking, rpm fluctuation, mataas na ang rpm mo sobra pero usad pagong ang otto at parang mamamatay during sapag abante galing sa full stop.....
    Jul 2016
    Quote Originally Posted by suysuy View Post
    [ame="http://www.youtube.com/watch?v=DQ05lgWHAcA"]http://www.youtube.com/watch?v=DQ05lgWHAcA[/ame]
    Wala na ata talaga itong pagasa! Since nabili namin itong sasakyan na ito wala pa isang taon ang dami nang problema! Lemon na lemon talaga ito. Dadalhin ko sa casa bukas. Sabi naman nila na baka pwede iclaim sa warranty kasi may records kasi sa kanila na matagal na ako nag kaka problema sa CVT ko. Im so disappointed kanina!!! i took this video habang nasa stop light ako. i was so shocked!
    Ang dami naming honda. pero ito talaga ang walang kwenta sa lahat. anyone would like to buy this for 50k?
    follow up lang bro, ano kotse mo ngaun? and whats your updates sa City?
Epic Failure Of My Honda City's CVT Transmission!
