Results 161 to 167 of 167
- Jul 2012
- 345
December 31st, 2014 09:02 AM #161will have to think about that.. im sure matagal na hindi na linis yung skin.
January 1st, 2015 12:49 PM #162
TAMA ito I agree na all jerking ay CVT na kagad ang verdict ng iba pero it could be misfire lang or kulang sa supply ng fuel dahil barado na dumi ng fuel filter or may water sa fuel pwede din so better check it out talaga maigi bago mag decide to replace a certain parts so be carefull during assessment nyo....ako muntik na mag palit ng transmission at fuel pump at coil packs na ang estimate ay nasa 20k petot plus so mali pala dami pa pala pwede panggalingan ng jerking, rpm fluctuation, mataas na ang rpm mo sobra pero usad pagong ang otto at parang mamamatay during sapag abante galing sa full stop.....
- Nov 2010
- 27
June 8th, 2015 03:57 PM #163My Jazz GD3 has problems when on reverse gear! When changing gears to R, a really severe and scary vibration occurs! There's even a clanking sound coming from, I guess the transmission!
I've been doing some back reading on this post and there's seems to be a lot to do to fix this. So if anyone can help, I'd like to know what to really do first!
-Change CVTF - done
-Change Transmission and Engine Supports?
-Change Start Clutch?
-Change Flywheel?
-Clean EGR?
-Clean Throttle Body - done
-Change Fuel Filter?
-Change Fuel Pump?
-Change CVT Assembly? - Hopefully NOT!
June 8th, 2015 10:41 PM #164
Sa reverse lang ba nagkakaproblema? If not pacheck mo rin ignition coils baka napuputol kuryente kaya kinakapos sa power minsan lalo na pag reverse....dalin mo na kay Mel Cabasa para macheck maayos hirap manghula mapapagastos ka malaki pag mali ang assessment....
- Feb 2017
- 7
February 25th, 2017 10:36 AM #165ok pasali sa thread having same problem with honda GD1 matic, jerking , shuddering from full stop , lakas ng vibration parang sliding clutch ang feel ,ano po gamot dito \
been reading some forum ang mga nabasa ako possible sira is , change CVTF wich i already did once problem still there , pwede din daw start up clutch ?, torque converter? PCV valve ? TPS ?
bali nagpalit na ko 8 NGK spark plugs , check coil pack ni youtube ko lang hehe 1 lang nakita ko sira , change honda CVTF 2 weeks ago
thanks
- Oct 2015
- 8
June 15th, 2017 02:34 AM #166Halos ganito din yung sa 08 City ko na CVT. we end up replacing the entire CVT. Inabot ng 20k Surplus japan, labor and CVTF included na. sa QC sa may Mindanao ave namin napagawa. So far nakakapanibago kasi ang smooth na, parang bago kung humatak.
Alagaan lang talaga yung CVT, mas ok sya kaysa normal AT na kotse.
- Jul 2016
- 8
June 30th, 2017 11:26 PM #167
