Results 141 to 150 of 167
December 5th, 2014 11:31 PM #142
December 6th, 2014 12:33 AM #143
Nashimoto nagreply na pala ako sa PM mo. CVT ko na surplus buhay pa din hanggang ngayon.
Basta pag nagpalit na kayo, wag nyo na gamitin yung 7 speed mode. I know masarap siya gamitin kasi "parang" mas malakas hatak, pero ang totoo dun, malakas ang rev tapos di mo minsan namamalayan nasa red line na pala rpm mo.
I may be stupid, but I am not a fool.
- Jul 2012
- 345
December 6th, 2014 11:18 PM #144ginagamit ko for short distance. yung tito ko mekanik may ginawa sa sparkplugs socket ayun hindi na nagwawala tranny.. as in tumahimik kahit idle.. pero ramdam ko parin yung topak ng tranny. will not be using the car for sometime until maka ipon ako pambili new tranny.. mahirap na.
- Jul 2012
- 345
December 6th, 2014 11:19 PM #145
December 10th, 2014 08:17 AM #146
Sir wezz_zzew, i learned na twice ka nagpalit cvt trans una kay mel then nasira ulet and then 2nd somewehere in banawe, tanong ko lang san mismo sa banawe ano name ng shop saka howmuch dun sa banawe at gano katagal replacement ng cvt surplus transmission...tsaka pala gano mo na katagal ginagamit yun 2nd transmission mo .....salamat
December 12th, 2014 09:12 AM #147
we almost had the same experience with my brothers jazz gd. rried to change cvt couple of times and we even had it for dialysis. wala din nangyari at bumabalik problem. ended up getting a surplus tranny at isahaya banawe. dun narin install.
- Jul 2012
- 345
December 16th, 2014 08:23 AM #148just used my car recently kaht hindi pa napapalitan trany.. 4x times tumirik! nung una ok pa.. pero nung traffik dun ko napansin na nagloloko nnmn sya from idle and stop and go. nag blink nnman yung "D" and check engine light is on. katakot.. buti umaandar pa after restarting the car!
December 17th, 2014 11:05 PM #150
2010 Honda City sedans have a completely different automatic transmission. It's a standard five-gear automatic with torque converter. The older models were continuously variable transmissions with a starter clutch instead of a torque converter. 2014 and up Honda City sedans use a CVT, also, but with a torque converter for better durability.
high idle RPM at engine start
