Results 1 to 4 of 4
July 4th, 2011 11:11 AM #1
good day mga sir patulong naman kung anung posible problem ng auto ko 2001 honda civic vti.last saturday tumatakbo ako ng 110kmph sa nlex bigla nalang namatay yung makina ko tapos try ko start engine ayaw mag start.gumilid ako sa nlex then check the hood check water oil and posible leak wala naman ako nakita.try ko uling start ayaw pa rin mag start sobrang kinabahan na ako.first time kc nangyari sakin to.pinahinga ko lang about 3mins then try to start ulit sa awa ng diyos umandar ulit..mga sir ano kya posibleng problema ng auto ko.posible ba fuel filter un?
any idea mga sir?tia
July 4th, 2011 11:27 AM #2
Baka may problem sa fuel line (i.e. filter). Check mo rin yung air filter baka barado na.
July 4th, 2011 11:47 AM #3
On gas engines, it all boils down to three things; air, fuel and a spark (ignition). You must have all three in order to have combustion. If you don't have one of the three, work your way back to figure out what's wrong.
Most common problems involves the fuel system and ignition.
July 4th, 2011 12:12 PM #4
Sounds suspiciously like a cam position sensor issue. Typically when they get hot, they fail, then they're okay again once they cool down. There's a recall on those, in fact, for that year model of Civic.
Another possibility is overheating ignition coils or throttle position sensor. You'll need to see a mechanic with a tester and a familiarity with newer models.
in some non-ford dealers', they offer a 30K cash discount, but the formerly-free LTO + compre...
2023 Ford Everest Owners Thread
