7. Install the ground cable (D).
8. Remove the air cleaner housing assembly.
9. Loosen the transmission mounting bolt and nuts (A).
10. Raise the hoist to full height if you have a lifter available. Kung wala higaan mo nalang sa ilalim para ma access ang tranny mount bolt.
11. Remove the engine undercover.
12. Loosen the lower torque rod mounting bolt (A).
13. Lower the vehicle on the hoist kung naka lifter
14. Tighten the side engine mount mounting bolts and nut.
15. Tighten the transmission mounting bolt and nuts.
16. Raise the hoist to full height kung may lifter, kung wala higaan ulit sa ilalim
17. Tighten the lower torque rod mounting bolt.
18. Install the engine undercover.
19. Lower the vehicle on the hoist.
20. Install the air cleaner housing assembly.
21. Install the upper torque rod (A), then tighten the new upper torque rod mounting bolts in the numbered sequence shown.
