Results 1 to 7 of 7
- May 2011
- 26
August 13th, 2011 05:31 PM #1Sabi kasi mekaniko kanina,may tama daw disc brake at malamang daw may napabayaan na brake pad na hindi pinalitan agad.Sabi nya kailangan ipamachine shop daw.600 daw ang isa.Honda civic vti '97 po car ko.Tama ba sinabi mekaniko?
Ask ko din mekaniko kanina kung yun brake pad muna papalitan ko at saka na machine shop pero sabi masmaganda pagsabayin nalang.
August 13th, 2011 07:52 PM #2
If you can see and feel grooves on your brake rotors, yes it would need to be repaired in a machine shop. Alternative is to buy new rotors.
Just changing the brake pads will not fix the problem. In fact the new brake pads will not grip properly into the grooved brake rotor.
August 13th, 2011 08:31 PM #3
^ Or maybe using Bendix Metal king would also do the trick. What do you think?
Bendix MalaysiaFasten your seatbelt! Or else... Driven To Thrill!
August 13th, 2011 09:56 PM #4
Bendix Metal Kings would offer more grip but would also eat up the rotors faster. I used to use metalkings before and I liked their bite, I have also already replaced my brake rotors because they got too thin due to the metalkings.
But the same issue will still be there... if the rotor is bad (grooved) it will still need to be worked smooth in a machine shop.
August 14th, 2011 06:47 PM #5
Rotors have a minimum operational thickness because heat dissipation becomes significantly poorer as rotors wear out. Check your owner's manual or shop manual for that. If the grooves are too deep and you're just 1-2 mm away from minimum thickness, save your machine shop money and just buy new rotors. Replace in Left-Right pairs.
August 19th, 2011 08:47 PM #6
rotor replacement will be the best solution IMO...you will save a little in refacing but your rotor will no longer be in its original specs although it will likewise solve your problem, my cent..
August 20th, 2011 10:19 AM #7
^ kung hindi pa na-rereface ang disc at hindi naman masyadong malalim grooves, pa-machine shop na lang. Mura lang vs a new set. Bili na lang ng magandang brakes pads at proper maintenance para tumagal pa. Try Bendix or Ferodo. OEM is also very good naman.
high idle RPM at engine start
