Results 1 to 2 of 2
- Oct 2006
- 23
February 12th, 2009 08:38 PM #1can anyone help me with my problem. i got a honda crv 2005 model. i changed my headlamp bulbs (H1) hi and low. attached the weather seal back in place and double checked it. now every time i use the headlights there are small water inside it (moist). i tried to remove the weather seal and turn on the lights, and i think it evaporates. the next day the water comes back again. the two headlamp has the same amount of moist (left and right headlamp).
during the day or when the headlamps are not in used the moist goes away. its very anoying.
how do i solve this problem??? thanks
February 13th, 2009 10:10 AM #2
have your headlight assembly sealed properly. it means may butas sya kung saan dumadaan ang moisture.
As long as it is valid, bring a printed copy. Then, they will ask you to use one of the PCs there...
