Results 1 to 10 of 10
- Apr 2008
- 32
May 13th, 2008 12:14 PM #1mga paps ano difference ng dalawa or pareho lang sila? ano mas ok kabit sa oto?
May 13th, 2008 03:53 PM #2
A well-designed short ram is the best way to go, from a safety and a power standpoint.
A cold air intake often takes air from the bumper area... which is a problem in floods. It tends to make better midrange, and if it's designed well, will give you some charge-air boosting and resonance tuning, giving more power than a short ram, but generally, it's not worth mucch more than the SRI. A short ram's only problem is heat soak in traffic, which can be minimized by adding a heat shield.
May 13th, 2008 04:11 PM #3
sir niky, what are cons when you have a set-up like this pero wala ppong heat shield .. im using K&N brand and i notice some HP gain and better FC ..
both cars have no heat shield ..Last edited by s_quilicot; May 13th, 2008 at 05:04 PM.
May 13th, 2008 05:14 PM #4
Pros, more intake air, better tubing (at least on the first one), which actually accounts for a lot of the gains in power.
Cons: no heat shield, may feel sluggish in hot traffic. MAF adapter may be altering air reading, causing a dip in power, but if it feels more powerful, then it isn't hurting your MAF, and you can leave it as is.
May 13th, 2008 06:56 PM #5
May 14th, 2008 04:52 PM #7
The MAF is the sensor screwed into the pipe.
Get a cheap Simota heat shield and it'll be perfect.
May 15th, 2008 02:08 PM #8
- Apr 2008
- 32
May 16th, 2008 07:45 PM #10
Yup, that's the MAF. And I don't know specific stores, but I'm sure Blade or Concorde has it.
Somewhat expected from a rushed car from a first time carmaker
Xiaomi E-Car
