Car zone said they don't individually bench bleed but do it when installed by tapping the brakes.
I want to know the technicalities.. Supposed you installed it empty and add brake fluid to the reservoir with air in the cylinders.. and you repeatedly press the brakes with the bleed valves in the brake calipers open (lahat ba na car meron bleed valve?).. can all the air be sucked out eventually or 100% required talaga ang bench bleed??
For modern cars, the EPS seems to be more ubiquitous as the traditional engine-driven PSF...
A/c
