Results 1 to 10 of 22
- Jan 2009
- 8
January 2nd, 2009 02:51 AM #1ano po best gas na gamitin sa 2009 jazz ko? xtra unleaded ba? xcs? o blaze? sa petron po kasi ako papa-gas e... o mas ok sa ibang gas company??? nagtatanong lang po... tnx!!!
ps: me sticker palang nakalagay sa cover nang gas ko. "use unleaded", so dapat ba unleaded lang??? pero sabi kasi nakakabagal daw nang makina yun e.
- Dec 2005
- 490
January 2nd, 2009 04:24 AM #2
January 2nd, 2009 09:33 AM #3
Follow what manufacturer's recommended on your manual. They have the best "Engineer" to tell you what to use and what not.
- Feb 2008
- 898
January 2nd, 2009 10:25 AM #4Although my car is not a Jazz, yet if the manual says use an unleaded gas, use it. The car manufacturer knows best. In my case, the manual says that I have to use unleaded gas, and gives a warning if I should use otherwise. Better be safe than sorry, bago pa naman ang tsikot mo. Happy new year...
January 2nd, 2009 10:59 AM #5
di ba lahat naman na ng gas ngaun unleaded? kahit V-power, Caltex Silver & Gold etc?
ang gamit ko noon sa jazz ko eh shell superpremium at 31 per liter... Project 8 QC to Northgate Alabang and back... around 76kms... using full tank method nasa 13.5km per liter.. slight traffic sa edsa walang traffic sa slex
nung nag palit ako ng caltex gold * 31 pesos per liter,, same route using fulltank method pumatak ng 15km per liter.. slight traffic sa edsa walang traffic sa slex
di ko alam kung dahil ba sa gas un kasi nagpalit din ako k&n drop in filter at nag palit ng mags.
January 2nd, 2009 11:00 AM #6xtra unleaded ba? xcs? o blaze? sa petron po kasi ako papa-gas e... o mas ok sa ibang gas company??? nagtatanong lang po... tnx!!!
From the grapevine, Shell has the dirtiest fuel. Petron is either the cleanest or second to the cleanest. Caltex also gives me an impression of not being clean also.
January 2nd, 2009 11:54 AM #7
Most fuels today are unleaded gasoline. Some provinces still carry leaded I think, but that's not the problem.
The problem is what RON octane to use. Typically, the cheaper fuel has a low RON octane rating. I would tend to believe that the Jazz was meant for regular unleaded fuel, the basic mix. See if that will make your car run well. If not, step it up to the next level see if it runs better then.
- Dec 2008
- 58
January 2nd, 2009 05:50 PM #8
Almost all gasoline right now are unleaded. Though I'm not driving a Jazz, I'd recommend Caltex's Gold with Techron. The higher Octane rating, the better for your car engine. You can also use V-Power of Shell, which has the highest Octane Rating among gasolines.
I'm using Caltex Gold for my civic and I can feel the power and good running of the engine. Though, mas powerful yung hatak kung V-Power yung gamitin. Slightly expensive nga lang.
January 3rd, 2009 12:42 AM #9
I recall the owner's manual recommends using unleaded gasoline with a minimum 90 octane rating. I usually fill up my '09 Jazz with Shell super unleaded which has an octane rating of 93. But please note that I use Shell fuel since it's station is nearest to my house and I get a 5% rebate.
Cheers.
- Sep 2008
- 1,219
January 3rd, 2009 01:46 AM #10ikaw din ba ang thread starter nito? http://tsikot.yehey.com/forums/showthread.php?t=55916 Best Leather Seat Cover for my Honda Jazz? saka http://tsikot.yehey.com/forums/showthread.php?t=55917
freshest car freshner for hondas???Last edited by actor21; January 3rd, 2009 at 01:50 AM.
Xiaomi E-Car
