Page 7 of 7 FirstFirst ... 34567
Results 121 to 132 of 132
    Jan 2016
    #121
    1st time I heard of RP Revalidation, this I don't know...
    Car wash is optional, you want cheaper, have it done outside, that's what they do anyway, bring it to a car wash outside
    On parts: just get the last 5 items, ditch all the others.
    I don't know if they are out of fully synthetic oil or they used semi to "bring down the cost" due to all the add-ons. Hanga din ako sa presentation, nasa top of the list yung unnnecessary items probably to give a semblance of importance.
    You may use their mineral oil (cheapest) if you want to cut costs further and if you don't really use more than 5k kilometers per 6 months. I use mineral oil because I only use less than 4k kms/6months.
    Dec 2018
    #122
    Thank you very much papismith!
    Upon checking Honda’s website, RP validation is all about rustproofing rechecking. I guess this could be waived as well. Hehe
    #123
    Usually libre carwash sa honda unless iniisahan ka ng dealer. X-1R no need.
    May 2012
    #124
    Bought a 2nd hand 9-year old Honda, plan ko ipasok sa casa for a maintenance check, after that would you suggest na sa casa pa rin palagi ipa-pm?
    #125
    Quote Originally Posted by Renzokuken View Post
    the owner's manual should list down the pms schedule, including the items to be done/replaced/checked/adjusted, and their time intervals.
    if you are comfortable with these, then you should be able to have them done outside the casa.
    but if you know next to nothing about cars, then i suppose the casa is the better choice for you. but it will be more expensive.
    good luck, po.
    #126
    Bring it outside at shops Honda owners go to have their maintenance. If you have the manual, just follow it.
    May 2012
    #127
    good luck, po.
    Thanks guys!
    The plan is actually to have the 'first' maintenance sa casa then for the next ones sa labas na.
    *Egan101 - would you know a shop near south area? (LP/Pque)?
    #128
    Thanks guys!
    Pitworkz Hongly and D&R Fast Auto along Sucat and Customer Cradle along Alabang-Zapote Road. Aircon check and cleaning at Ceejay’s along Alabang-Zapote Road.
    Jan 2016
    #129
    No need for casa if you bring it to the shops mentioned by Egan, mga "honda" shops ito.
    Simply have the following replaced:
    all fluids and filters, make sure you use ONLY genuine AT oil and power steering fluid. Follow the specs needed for all other fluids, the shops mentioned will know what to use
    timing belt (if it's still not chain)
    check and adjust brakes
    suspension if you feel something creaking or wrong
    no need to have aircon checked or cleaned if still working properly, just replace the filter
    May 2012
    #130
    Thank you guys! Tips saved!
    #131
    wala na ata dito sa forum yun "ahente" ng x1-r...
    #132
    "in hibernation."
Attention: Never avail this at preventive maintenance sa casa
