Page 5 of 7 FirstFirst 1234567 LastLast
Results 81 to 100 of 132
    #81
    Quote Originally Posted by ;2856684
    Casa aircon/cabin Filter is definitely more expensive! Just note that there are more FILTER FINS as compared to the replacement. Even the original engine air filter has more fins. In other words, they are more efficient in collecting dusts.
    increasing the number of fins does not increase the efficiency of collecting dusts.
    it merely increases the effective surface area, resulting in more air passing thru per unit time.
    mas malakas ang buga ng hangin ng aircon, kapag maraming accordion sa filter.
    Aug 2016
    #82
    kung mapapa preventive maintenance kayo sa casa ito ang example na pwede nyo irefuse.
    example
    aircon filter
    casa = 2,300 ( basic made in thailand..)
    banawe = 400 to 600 (replacement )
    See the big difference.
    Isa pa dapat iwasan yung "lubricants" daw ilalagay sa makina.
    sisingilin ka ng 1,900 for that anonymous lubricants.... hindi maexplain para saan yan.....
    Ang kailangan lang sa makina eh engine oil......
    Wag magpabola.... Ask for the breakdown first and just refuse sa mga unnecessary....
    Also refuse the flushing fluid...... another gimmick ng casa....
    Updated pa ba to? Ano ano ba pwedeng ipa waive sa casa pag nagpa PMS?
    Sent from my Redmi Note 4 using Tapatalk
    Nov 2017
    #83
    Quote Originally Posted by cute_boyz View Post
    depende yan sa casa [emoji31] dapat talaga me breakdown before nila gawin maintenance [emoji106]
    Aug 2016
    #84
    Quote Originally Posted by maxpedition View Post
    Paki check naman ito. Nakuha ko lang sa isang group. Credits to the owner.
    Alin kaya Jan ang pwedeng tanggalin? Yung hindi naman kailangan sa PMS.
    FB_IMG_1511877581352.jpg - Google Drive
    #85
    i'd OK only the oil and oil filter w/ washer, and the air filter.
    i'd wash my aircon filter, instead of replacing it.
    i'd even go mineral oil instead of synthetic.
    the rest, "next time na lang po, at wala sa budget, e". (translation: you can do it, but don't charge me, as i don't have the money to pay for it.")
    good luck.
    Jan 2016
    #86
    Tanggalin mo Items 9-13 easily 5k savings on unnecessary items. Other jobs pagawa mo sa labas kung gusto mo, mas mura, yun din naman gagawin nila, may cut pa sila. If you backread, malalaman mo kung bakit di kailangan nung mga items na sinabi ko.
    Feb 2012
    #87
    Items 2-4 is par for the course, although you can buy a Baldwin, Donaldson or Fleetguard filter which will be cheaper and works much better. For the engine oil, that's the casa price for the Toyota 5w40 FS oil, but you can find it cheaper outside, that is, if you're even allowed to bring in your own oil. As most here have already mentioned, you may forego of items 7 to 16.
    Jan 2016
    #88
    Actually ako nag waive na talaga ako magpa PMS sa casa, 4.5 years and running, change oil and other essentials lang sa suking talyer
    ^ same here. Inantay ko lang mag 20k kms tapos hindi na ko bumalik uli sa casa
    when you look into the abyss, the abyss looks into you
    go for their semi synthetic oil and oil filter and that overpriced washer and intake air filter
    get the ac filter outside. di naman kaagad masisira ac system unless mabangga ka..
    Aug 2017
    #91
    Nakalagay na mismo sa manual na huwag lagyan ng engine oil additives kasi makakasama sa engine. Pero inoofer pa rin ng casa yung X-1R.
    Dec 2009
    #92
    ^defying the manual is the biggest sin of these car dealers
    Sent from my GT-P3110 using Tsikot Forums mobile app
    #93
    Quote Originally Posted by ieddam View Post
    Dagdag kita. Di naman sa kanila yung sasakyan.
    Sent from my SM-T705 using Tsikot Forums mobile app
    Sep 2009
    #94
    Need your opinion and advise:
    Barely using my other car as it is only for coding purposes. It's now 6years old (bought brand new first hand) and only 35Tkm.
    I still prefer to bring it to casa, has been like that since I bought it from the dealer. My last PMS was Dec last year when it reached 5yrs old.
    Now what will be the absolute minimum replacements and services you recommend. My understanding, these are as follows:
    1. Change oil and oil filter
    2. Air filter?
    3. Tire rotation
    4. Check fluid levels, top-up/replace if needed
    5. Bolt tightening
    What else?
    I don't think I need to replace cabin filter as I always use closed flap (recirc).
    Thank you.
    I would change the atf. if its a 4spd toyota, the atf might not be pink anymore.
    Dec 2009
    #96
    Quote Originally Posted by ano727 View Post
    2. Air filter?
    3. Tire rotation
    5. Bolt tightening
    What else?
    Thank you.
    Since youll have the tires rotated..have the brakes cleaned..pacheck mo na rin kung may grasa pa yun wheel axle..pacheck mo na rin yun bearings sa wheel axle kung buo pa
    Dont forget to have the wheels balanced after rotating
    Nov 2017
    #97
    For normal tire wear, there's no need to re-balance it after a tire rotation.
    include brake caliper guide pin greasing... its been 5years.. baka dry na yan.
    #99
    it is possible, that their definition of engine oil additives, is different from yours... or ours.
    Sep 2009
    #100
    Thanks Bro, it's CX9 by the way.
Attention: Never avail this at preventive maintenance sa casa
