Results 201 to 210 of 261
February 15th, 2015 04:42 PM #201
I have read good feedbacks about mel casaba. Mukhang sya dapat ang pinuntahan ko kaysa nagsayang ako ng pera dun sa huling mechanic ko. Im from valenzuela city pa. Kung okay sya talaga dadayuhin ko na. By the way i own honda civic vti-s 01, first time ko lang magtsikot kaya medyo onti palang ang alam. My problem is that after i release the break pedal may lumalagutok.(sabi mechanic normal?)
Another thing, habang umaandar ako maingay sounds like (chug-chug-chug) parang nakadepende yung sound sa bilis ng andar. First the mechanic told me break pads daw. Then caliper kit changed. Then axle changed. But still ganun pa rin. Please help mga bro. Thrice nako naglabor wala naman improvement. Any suggestions please. Sorry haba ng post. Thanks
February 15th, 2015 04:47 PM #202
Sa mga batikan na sa honda please give me suggestions. Dipa ako talaga maalam kasi. Plan ko narin magpachange oil. 2nd hand lang tsikot ko kasi. Ano rin po kaya maganda motor oil? Thank you. Sana maayos na oto ko. Di malaman laman nung mechanic sira. Honda civic vti-s 01.. AT po.
- Mar 2014
- 901
February 15th, 2015 07:30 PM #203Any good motor oil will do bro. Like SAE 40. Or SAE 20w-50. Just look for their API Service SG or SH. This oil is formulated to help your engine use less fuel. Sa brand ng motor oil, any petron or shell or caltex will do, its up to your choice. Me, I prefer Shell Helix.
- Jan 2015
- 468
February 15th, 2015 11:30 PM #204Sir para hindi ka magsayang ng pagod at oras, ganito muna gawin mo - wag ka atat magpagawa.
Second, punta ka sa Goodyear Servitek or kahit anong mamahaling repair shop na willing i check ang oto mo until maka 3 diagnose, dun lang muna sa free para wala gastos at syempre ang importante magpaquote ka muna.
Suggestion ko pumunta ka din kay hotwheels sa evangelista maayos din dun at underchasis expert sila.
Pagmay quote na at diagnosis, bili ka ng piyesa, sorry wala akong alam na murang bilihan ng piyesa malapit sa inyo.
Tsaka mo dalhin either sa may pinakamurang pagawaan or kay mel casaba.
Delo gold ultra magandang oil, afaik, kahit ung sa hondaclubphil dati yan recommended oil nila.
Sa piyesa ipost ko mamaya ung item by item na quote sa akin ni alabang parts center para may guide ka na. Ang kulang labg duon eh upper arm at ball joint, bapalitan ko na kasi.
Hula ko it is either stablink, upper suspension arm and/or ball joint.
HTH
- Jul 2012
- 345
February 16th, 2015 07:06 AM #205just got my car serviced by mel kahapon - yes even on sunday binuksan nya shop to check my jazz. tama hinala ko na ignition coil nga kasi pag ka start plng ng makina kahit nka "P" pa lang eh lakas na ng nginig. checked sparks, cleaned ignition coils, ayun na determine namin yung isa busted. after cleaning and doing some remedyo eh nawala na nginig. in the end ipon muna for a new set of ignition coils. thanks Mel! even on a sunday you never hesitate to check my car. pang merienda lang ok na!
- Mar 2014
- 901
February 16th, 2015 08:08 AM #206
- 52,731
February 16th, 2015 01:40 PM #207kung gusto mo talaga kay mel, ay dumeretso ka na sa kaniya.
wag ka nang makipag-sapalaran sa iba pa, at baka iba ang sabihin ni mel..
- Jan 2015
- 468
February 16th, 2015 01:59 PM #208
- Mar 2014
- 901
February 16th, 2015 04:53 PM #209If not engine mount support was the problem of your Civic. Try to Inspect/check some of the followings :
1. Suspension arm, its bushing and ball joints. Determine if there is no loose bolts attaching them to their bushing and ball joints.
2. Rack ends and tie rods.
3. Rack and pinion mount bushing. Any loose bolts or deteriorated rubber mounts or bush in its mounting brackets may lead to some knocking sound while or during driving.
Sent from my Starmobile UP+ using Tapatalk.
February 17th, 2015 12:12 AM #210
Mga bro. Rotor reface lang pala katapat nung problem ng unit ko. And yung breakpads ko pinalitan ulit ng bago. Okay na takbo. Wala na kaingay ingay. Medyo sablay lang siguro yung huling mechanic nalapitan ko. Nasa bakasyon kasi yung mechanic ko last time kaya sa iba ko nagpaayos. Pero pag unavailable uli mechanic ko alam ko na san takbo ko >>(mel's place). Next in line na yung mga bushings. SALAMAT SA LAHAT NG INPUTS NYO MGA BRAD.
Somewhat expected from a rushed car from a first time carmaker
Xiaomi E-Car
