Results 1 to 7 of 7
- Dec 2011
- 70
September 20th, 2020 08:03 PM #1Ask ko lang kung ok lang magpalit ng 90 amperes na alternator for Civic 2000 Lxi para mabawasan yung nginig ng makina?
Nagtry na kasi ako ipalinis yung servo tapos pinalagyan ko na din ng ground kits, pero may times na pag naka-dim medyo may kurap yung mga ilaw ng guage pati ng headlight. Tapos medyo manginig yung makina.
Para bang umaandap andap, Amaron na nga battery ko pero parang mahina yung alternator.
1. Ok ba magpalit ng 90 amperes?
2. Saan makakabili ng 90 amperes for Civic 2000 Lxi?
3. Magkano?
Thanks in advance!
- 54,234
September 20th, 2020 08:15 PM #2if the alternator you have now is the original alternator before it went nginig,
it would appear,
that there is something wrong with the engine and not the alternator.
with the information you are surrendering, my guess is that your engine is idling too slowly.
have you consulted a decent mechanic? ano sabi niya?
replacing the alternator may not be a guarantee that the nginig of the engine will disappear.
good luck trouble-shooting your car, sir.Last edited by dr. d; September 20th, 2020 at 08:24 PM.
- Dec 2011
- 70
September 20th, 2020 08:26 PM #3
September 20th, 2020 08:52 PM #4
Is the vibration always present?
Honda ignition coils are popular in some forums. As well as grounding wires. Age tells me engine mounts.
I dont want to lead you into a rabbit hole but have someone check it instead of expensive and sometimes unnecessary trial and error replacements.
- May 2006
- 1,668
September 21st, 2020 12:41 AM #5What is your idle rpm, with and without aircon. Cold and warm engine.
So 4 rpm scenarios yan. Let us know.
Doubt its alternator if the car starts normally and reliably.
September 21st, 2020 12:14 PM #6
engine mount din naisip ko.
No idea why issue yung alternator - not unless may issue ka sa charging ng battery
- Dec 2011
- 70
December 18th, 2020 01:53 PM #7Thank you sa inputs niyo mga sirs lalo na sa iyo sir StockEngine.
Napaayos ko ko na last week lang, pinapalitan ko ng engine supports (Left,Right,Rear) original binili ko at ang laki ng improvement, naayos lahat ng concerns ko like yung nginig ng sasakyan at iba pa, hindi pala sa aternator ang problema. Matagal kong tiniis yung ganoong condition ng kotse ko yun pala yun lang ang problem engine support. Hindi na ramdam nginig ng makina sa loob ng kotse. Salamat ulit sir StockEngine! God Bless...
Is it true na may recall ang yaris cross hev recently regarding sunroof issue? Lol.
China cars
