Results 251 to 260 of 491
May 24th, 2020 07:00 PM #251
For this vehicle the ground clearance is 150mm as stated in their website is this among the lowest ground clearance for vehicle in its category?
May 24th, 2020 07:20 PM #252
May 24th, 2020 07:38 PM #253
Smaller cars seem to have higher ground clearance than bigger sedans. Our old 2009 City sits higher and stands taller than our old 2001 Accord. The Accord is lower to the ground and wider.
The 2016 Jetta also sits as low as the 2016 Civic in terms of ground clearance. Almost as low as the Accord.
- Jun 2011
- 1,081
May 24th, 2020 07:47 PM #254Heto, mukhang ok na video sa injector location:
Episode 28. 2008 Honda Fit fuel injectors replacement. - YouTube
Oo nga, tapos iyong windshield at dashboard lagpas sa firewall, kaya na takpan partially ang access.
Na appreciate ko tuloy engine bay ng new Ertiga.
May 25th, 2020 10:42 AM #255
May 25th, 2020 10:54 AM #256
OT:
For this type of dirt inside car sidings is it okay to use MC or Wipeout or need to buy upholstery cleaner? this are tough stains to remove.
- 52,731
May 25th, 2020 11:34 AM #257
May 25th, 2020 11:40 AM #258
- 52,731
- Sep 2016
- 2,280
May 25th, 2020 11:53 AM #260Honda GH has big glass windows facing the service bay so you can see your car being serviced. They also allow you to watch beside your car if you want. Ewan ko lang ngayon kung pwede pa due to the virus pero malamang hindi na.
Nung December na last PMS ko, I was there beside the car nung nagpaturo ako paano magpalit ng headlight bulb. Dala ko na yung Orsam NBL at dun ko pinakabit. Pinanood ko lang pano palitan. Mahirap pala sa mataba ang kamay.
high idle RPM at engine start
