Page 63 of 137 FirstFirst ... 135359606162636465666773113 ... LastLast
Results 1,241 to 1,260 of 5300
    Oct 2017
    Quote Originally Posted by SpinCycle View Post
    You may want to start looking into the lemon law and see if it will apply to your case.
    I'm giving them time to fix it sir pero pag wala pa din nangyari i will consider that option.
    Just got the CRV back from the detailing shop. Availed of C.Quartz coating for 10.5k at ATMT Car Care. Let's see how this stacks up vs the regular carwash and wax regimen.
    Mar 2004
    That is why some people avoid buying the first batches of a newly released model ...
    Oct 2017
    Solved na stiff/heavy steering wheel. They deliberately tightened the steering wheel to see if the knocking sound will be fix. Unfortunately nandun pa din. The problem is nakalimutan nila ibalik sa normal setting yung stiffness ng steering wheel kaya matigas sya when i drove it. They just adjusted it through computer and its now ok.
    Aug 2017
    Quote Originally Posted by Bokyoo View Post
    So only the knocking sound really the main problem. The steering problem is cause by negligence of the casa to set back to the normal setting of the steering wheel when they are looking the knocking sound problem and now ok.
    Sent from my iPhone X using Tapatalk
    Oct 2017
    Quote Originally Posted by montro View Post
    Yes bro the knocking sound is still there. A while ago when i drove it passing on rough roads i also heard a clunking noise, sounds like metal. It's not the same rattling sound I've been complaining before.
    Oct 2003
    Nice! Mura na ha. C.Quartz UK edition? Or C.Quaartz Finest?
    Quote Originally Posted by zechs View Post
    UK Edition lang. Mas mahal yung Finest eh.
    Jun 2009
    Question lang mga bossing, what's the radiator like thing that's inside the driver side wheel well?
    Ang weird kasi ng placement for a breathing mechanism to be since it would get dirty and clogged up in no time being inside the wheel well of a car.. Tapos pag baha pa..? Na sa lower section pa naman siya.
    Jan 2011
    Quote Originally Posted by supercar10 View Post
    Intercooler yun bro. yes, weird ng placement ng Honda even for the civic ganun din...
    Jul 2016
    Sealed system naman sya, kahit lubog sa tubig no problem. Just powerspray it pag nag papa carwash ka para malinis.
    Nov 2017
    Sir jut forgive me for my innocence. Anu po advantage pag nagpa car detail?
    as the name implies. detailing or cosmetic detailing or automotive detiaing is improving appearance inside and outside. paint detailing's goal is making the paint look perfect.
    protection via wax, sealant, coat, film are different ways to protect the detailed vehicle.
    best free photo upload sites
    Quote Originally Posted by dongmilot View Post
    Glass coating keeps your car shiny and protects it from swirl marks and hairline scratches, so basically it has the same effect as regular waxing.
    Pros - you just do it once and you're done. Cons - expensive, and tbh it doesn't look that different from a car without glass coating.
    Dec 2017
    from experience, glasscoats/ceramic coats aren't really an end-to-end solution to scratches or swirls. swirls can still develop (and be seen in spotlight/sun) with improper washing technique.
    otherwise, they do make cleaning much easier and our dark grey paint stays cleaner for longer between washes.
    to the true-blood aficionadoes, "every little bit helps".
    to the everyday person, "it doesn't matter if there are swirls or not".
    Quote Originally Posted by drew_cc View Post
    Kahit naman wax magkakaswirls din. And I've come to accept that swirls are a part of life. It's not something I stress about anymore. [emoji16]
    Nov 2017
    Thanks for the reply.
    Thank you Sir StockEngine.
    I noticed that gas CRVs use the Toyo Proxes R45 as the OEM tires, while the diesels use Michelin Primacy 3ST.
    I wonder which is the better performing tire between the two. There aren't much reviews online for either.
    Jun 2012
    re knocking sound, I had that prob before on my gen 3. And yes it is because of the EPS.
    But as you stated kahit hinigpitan na, the toktoktok sound is still present, did they already check the top shock mount?
2017 Honda CR-V Turbo and 7seats
