Results 4,721 to 4,730 of 5300
July 25th, 2019 12:24 PM #4721
Saan engine support yan? Yun sa ilalim?
Or yun parsng sa FD nasa ibabaw lang?
July 25th, 2019 12:34 PM #4722
July 25th, 2019 12:43 PM #4723
- Apr 2009
- 110
July 26th, 2019 01:22 AM #4724Decided to play around and tinker with the reverse light bulbs by replacing those with LEDs. I got two different styles on Lazada, labelled as "LED 1" and "LED 2" below:
At a glance, it seems like LED 1 will be more brighter because of the sheer number of chips. But for objectivity's sake, I decided to get quantifiable data by measuring the total luminous flux emitted by those three light bulbs using an integrating sphere setup. Below is a pic of a partially inserted bulb to get an idea of the brightness:
and below is an image of the setup with the bulb fully loaded on the sphere:
Long story short, here are the results:
So its LED 2 that is the brightest at around 940 lumens; alam na kung sino ang ikakabit pabalik sa sasakyan, hehehe [emoji16]
Now at least lahat ng exterior lights totoong LED na. [emoji41]
July 26th, 2019 06:57 AM #4725
July 26th, 2019 06:58 AM #4726
Link naman nun LED bulb sa Lazada.
- Apr 2009
- 110
July 26th, 2019 07:54 AM #4727Hi sir, yung mga brake lights at turn lights ay LED na, kaso integrated unit sila. Meaning walang parang "bulb" na natatanggal para mapalitan, as an assembly sila pinapalitan. For diesel variants, all-LED ang buong headlight-turnlight-DRL combi:
For gas variants, halogen yung low (#5) at high (#9) beams, pero LED yung DRL at turnlights:
All models have an LED combi (#1/3) brakelights, taillights, and rear turnlights. Reverse light (#8) lang ang hindi:
Here you go sir:
LED 1
LED 2
July 26th, 2019 08:12 AM #4728
- Apr 2009
- 110
July 26th, 2019 08:56 AM #4729Actually sa Honda US yan sir, so hindi exactly the same with ours with respect sa engine.
Pero for body panels, pwede nang gawing reference, nabaklas ko na actually buong tailgate panel ko by referring to US diagrams. Also did some preliminary / exploratory baklas sa A-pillar panels & dash panels para sa next project ko na dashcam installation (hardwired, ayaw ko nang may nakakabit sa aux socket) [emoji28]
OEM Honda Parts Online - HondaPartsOnline.net
July 29th, 2019 09:50 AM #4730
high idle RPM at engine start
