Page 88 of 442 FirstFirst ... 387884858687888990919298138188 ... LastLast
Results 1,741 to 1,760 of 8838
    Aug 2012
    #1741
    Kelangan daw ba talaga i-break in? Sabi ni agent kahit di na daw kasi ginawa na daw yun sa factory something.
    Break-in is optional. But given that the break-in period is just for the first 1,000 km, bakit hindi mo pa gawin? It may add to the performance, economy, and life of the vehicle. Simple lang naman ang guidelines.
    For the first 300 km:
    - Avoid hard braking or sudden stops.
    For the first 1,000 km:
    - Do not race the engine. Do not drive at extremely high speeds. Max speed 80-90 km/hr.
    - Vary your speed frequently. Run the engine at moderate speed between 2,000 and 4,000 RPM.
    - Do not maintain one constant speed, either slow or fast, for a long period of time.
    - Do not drive constantly at full-throttle or high engine RPM for extended periods of time.
    - Avoid full-throttle starts and sudden acceleration.
    - Do not drive continuously in low gears.
    Nov 2014
    #1742
    Thanks for all the recommendations. but i'll go for the rain gutter siguro and busina. Di ko pa afford yung rear cam e. Nag canvass ako sa blade parang aabutin ng 30k e. Hehe. Yung back sensor may idea kayo magkano yun pati installation?
    Nov 2014
    #1743
    Thanks thanks!
    By the way guys yung econ feature ba you'll push it right after you start the car (the car is at stop) or you can use/push it while you're cruising?
    Congrats brod! Sakin sa martes ko pa makuha. Dapat kahapon e kaso kulang na sa oras hanggang 5pm lang kasi yung honda alabang. Natuloy nako sa honda alabang bro.
    Dec 2014
    #1744
    Quote Originally Posted by sensen View Post
    Di kita ma message bro full ata inbox mo.
    kagabi ko lang nakuha :D
    Practice practice pa muna ako mag drive bago ilabas ng village :D
    Buti natuloy ka din dyan sa alabang.
    Nov 2014
    #1745
    Ako din ganyan mangyayari sakin practice practice dn tagal k na kasi di nagddrive more than 8 yrs na ata hehe. Magerase ako mamaya ng message sa inbox. Hehe. Paturo din ako nung sa econ na yun pano paggamit hehe censya na newbie din.
    Apr 2014
    #1746
    You can turn it on/off any time you want
    Nov 2014
    #1747
    Quote Originally Posted by manzi View Post
    Ah ok sir, anytime i want means kahit nakatigil or umaandar na ang car pwede i-turn on yun sir? And ano magiging epekto non? Censya na newbie e. Wala pa manual sakin. Ang alam ko lang e pampatipid ng fuel consumption yun. Well, pano sya gumagana at nkakatulong sa pagpatipid ng fuel? Censya dami tanong. tia.
    Jan 2014
    #1748
    Yeah mas gaganda fuel efficiency ng city pag naka on but it will affect the performance of the engine. Like kukulangin ka sa hatak. Kaya mas advisable sya i on kung heavy traffic at chill driving ka lang sa city. Pero kung madaming sakay, mejo hassle kung naka ON sya. Enjoy the ride!
    Nov 2014
    #1749
    Quote Originally Posted by rhadski View Post
    Salamat boss! Malaking tulong yung advice mo. Gagawin ko yan. Off ko lang sya pag madami sakay at pag pataas ang daan. Then i-on kung patag ang daan at kung traffic. ask ko na din, tinatanong kasi ako nung agent ko kung magpapa additional rust proofing daw ako? May charge daw na 4,950pesos. Di ba nka-rust proof na to paglabas pa lang ng planta? Ano po ba maaadvice nyo sakin?
    Sep 2005
    #1750
    Guys, I find the horn of the City very weak. Hindi pinapansin ng mga tao at ibang kotse yung busina sa sobrang hina.
    Plano ko magpakabit ng either Bosch or Hella para lumakas naman pero plano ko ipalagay sa likod ng grille.
    Possible ba ipalagay dun? Anyone here na naka try na dun?
    Sep 2005
    #1751
    sorry double post
    #1752
    Mga bossing may delay ba yung turn signal niyo sa instrument panel after turning it off manually?
    For example. You want to turn right, but suddenly decided not to. So ibabalik mo sa off position yung turn signal stalk, after turning it off may display pa din sa instument panel ng 2 blinks before it completely shuts off. pero kung tinuloy mo yung pag turn right mo, automatic naman pag bawi mo mag o-off siya wala naman ganun delay. 1st time ko kasi naka encounter ng ganon.
    #1753
    #1754
    Quote Originally Posted by Uno^ View Post
    Naexperience ko rin yan pero OKs lang naman sakin yung delay na yun. Ang napansin ko lang sa gm6 ko is parang hindi deretso yung wheel alignment nya. Di ko sure kung dahil ba sa sobrang gaan ng steering wheel natin kaya di ko masabi kung naka gitna na sya. Unlike dun sa altis namin, feel mo kung gitna na sya
    Oct 2009
    #1755
    Kung hindi gumitna alignment.
    Kung hindi bumabalik sa gitna pag turn.. camber
    #1756
    Haha lagi ko nararanasan yan. Mukhang lahat naman pala ganyan. Akala ko nga nasira ko na eh? Sabi ko confused ata itong turn signal, pinatay ko na blinking pa din.
    #1757
    Quote Originally Posted by runner10 View Post
    Very weak talaga. Sa loob lang siya malakas.
    Wala nga pakelam mga jeep kahit babaran mo ng busina, parang walang dating kako.
    Ako din planning to have it changed, kaso limited choices sa dealer. Baka kasi warranty is voided pag pinapalit sa labas.
    Aren't all horns plug and play? Para wala issue sa electrical kahit papalitan sa labas.
    Dec 2014
    #1758
    Guys may beep sound ba yung sa inyo pag door lock and unlock using car key remote?
    #1759
    *cast oo nga bro ang weird may ganun pang delay, iniisip ko kung bakit at ano ang use nun.
    *dhisky beep sound na parang sa digital watch na tunog or yung usual na beep sound ng car alarm lock/unlock? None, unless may car alarm unit mo bro.
    #1760
    May beep when i lock it using the button on the door handle. Pero pag remote gamit ko no beep.
2014 Honda City (Gen 4)
