Results 8,571 to 8,580 of 8837
- Aug 2016
- 38
March 9th, 2019 06:23 PM #8572
Hi Tagal ko nawala dito - yung 2014 Honda City ko Experience ko so far.
1. 2018 - 2 radiator fans sira kasi hindi masyado nagagamit.
2. Front passenger tire side humps (Brigestone Turanza - 185/55/R16 83H OEM) - replace ko na ng achilles try ko ung 4 na tires although makapal pa yung thread ng tires distance travel so far is below 20,000km. Bigla siya nagkabukol.
Anyone tried the 2233 Achilles Tires 185/55/R16 83V? So I decided to change all my tires benebenta ko ung 3 tires ko sino may gusto?
Need ko po ba ng wheel alignment at iba pa?
Cradles daang hari price list below
Camber Correction Ord. - 750
Change Tire - 80
Tire Mounting - 120
Tire Rotation - 60
Vulcanize - 170
Wheel Alignment - 800
Wheel Balancing - 960
Reasonable naman po pricing nila diba?
- Apr 2015
- 64
March 14th, 2019 12:15 PM #8573Wheel balancing is done every time the tire is put on the wheel. Libre na 'to dapat pag bagong bili yung tires ah. Well, dun sa binibilan ko ng gulong e libre, hehe.
Yung wheel alignment, is kung may sintomas ng unalignment yung wheels mo. Uneven tire wear, google mo kung alin pa yung iba. Ginawa ko lang to dati nung parang pag high speeds e may pull sa side sa steering ko. Nagpawheel alignment ako, 300 sa may Motech Mindanao Ave. Although sabi nila aligned naman :\ Ewan ko kung pano naayos lols. Pero chinecheck ng honda ang alignment ng wheels every maintenance e di ba? Parang. Hindi ko lang mahintay yung schedule ko kaya nagpawheel alignment ako sa labas.
Anu pinagkaiba nung change tire sa tire mounting?
Baka naman yang Cradles e tipong may aircon lounge pa na may Netflix at libreng juice and what nots kaya ganyan ang presyuhan.
- Oct 2013
- 170
April 12th, 2019 07:47 PM #8574I'm about to change my stock tires (175/65R15) on my 2014 E CVT.
Anyone here changed to 185/60/15 or 195/55/15 on stock E CVT mags? Hows the ride and what brand of tires did you get?
April 13th, 2019 09:07 AM #8575
- Jan 2015
- 36
April 19th, 2019 11:17 AM #8576Pwede po bang humingi ng recommendations regarding led lights for high and/or low beam. Anong temp, lumens,brand, price at kahit ano pang info na pwede malaman.
I'm looking at replacing just my high beam to all weather sana na LED lights
Salamat sa mga magrerespond
Sent from my SM-G965F using Tapatalk
- Jul 2017
- 286
April 19th, 2019 06:40 PM #8577nagpa pms at change oil ako sa casa dahil 20k kms na odo ng city namin. Diko alam kung nascam ako pero sinabi ng mekaniko na pudpud na daw brake pads tas kelangan na daw palitan para di masira rotor disc tas sabi 8k+ daw bagong pads with labor na. pero di na ako pumayag na palitan nila kaya sa servitek ako nagpapalit. bendix ung brand ng pads nila 1.1k plus 600 na labor. tanong ko lang ok ba ung brand na un?tia
Sent from my RNE-L22 using Tapatalk
- Jan 2015
- 36
April 19th, 2019 11:01 PM #8578
- Jul 2017
- 286
April 20th, 2019 06:29 AM #8579
- Jan 2015
- 36
April 20th, 2019 06:33 AM #8580
high idle RPM at engine start
