Page 403 of 442 FirstFirst ... 303353393399400401402403404405406407413 ... LastLast
Results 8,041 to 8,060 of 8838
    #8041
    Quote Originally Posted by em22898 View Post
    Bro, mind sharing your technique.?
    Afaik:
    While on D (not S), if about to overtake:
    - press the gas a little bit more, then pull the minus (-) shifter (para mag change sa lower gear). Engine will rev higher.
    - to overtake, while rev is high, hold on to the gas and pull the plus (+) shifter.
    One time ko lang ginawa, pero parang may kulang. Hehe.
    May kulang? It's probably what you're thinking that the tranny should act exactly how a m/t would, which would never be true at all. Of course, iba pa rin talaga ang hatak ng m/t tsaka since cvt yung sa honda, may delay parin sa acceleration, hindi basta yung biglaan. If you want it to stay on the same gear, what you do is put it to 's' then engage the paddle shifters. That way, nasa manual mode ka na once you do it. The shifting will be on your hands until you return it to drive.
    Feb 2016
    #8042
    Sorry, didn't state clearly. May "kulang" means, parang hindi complete yung aking procedure or technique. Not about the delay or something..
    Anyway, So you still need to shift to S..? Okay. Got it. Sa D ko kasi ginamit.
    Thanks sa reply.
    #8043
    Sorry, didn't state clearly. May "kulang" means, parang hindi complete yung aking procedure or technique. Or baka lang wala sa timing.
    Thanks sa reply.
    'S' po sir then engage the paddle shifters if you want it to stay in one gear. I'm not sure lang if pwede mong i-redline pero parang hindi ata. Pwede ring stay at 's' and the engine will rev more higher than in drive, therefore it will also become more responsive. Kaya binanggit din na mas ideal sa uphill/downhill and overtaking dahil dun.
    #8044
    Sa Sports mode If hindi ka mag change gear, siya pa din mag upshift automatically.
    Mas higher nga yung revs compared prior shifting compared to D kaya mas malakas sa konsumo.
    Ako hindi ko gaano nagamit, lagi lang on D kahit uphill or downhill gamit lang talaga paddles.
    #8045
    ^^^ The previous generation City 1.5E (with paddle shifters) shifts gears automatically past 5k rpm when put on Sport mode as far as I can remember. It was a bit of a challenge revving that car to redline.
    Nov 2017
    #8046
    E variant lang un sakin. Haha. Wala paddle shifters.
    Nov 2017
    #8047
    Ang question ko pala ay when nyo nilalagay sa S? Ok lang ba nakaapak pa rin sa gas? Triny ko kasi minsan pero nagrev xa at parang bumagal ako. Wahaha. Ayaw ko muna uli itry baka masira ko.
    #8048
    Quote Originally Posted by rinkana View Post
    I was talking about the previous generation City. Back then, only the 1.5E variant had the paddle shifters.
    I guess that is expected if the engine shifted down a gear.
    #8049
    Of course nakaapak pa rin sa gas. Pano ka bibilis kung hindi.
    You use S when you need the engine to downshift so you get better acceleration for overtaking or uphill climbing.
    If you put it sa S tapos bitawan mo accelerator, siyempre babagal kasi tumaas yung revs so nag-engine brake yung kotse.
    Kahit ibaon mo lagi yung accelerator at irev mo laging to 6000 rpm at gamitin mo lagi ang S mode, hindi masisira yan. Hindi laruan yung kotse, matibay yan.
    #8050
    Afaik:
    Bakit mo pinipindot yung (+) shifter while overtaking??? That would make the car upshift in the middle of the overtake, taking you out of the powerband, which is what you DON'T want.
    Your step one is correct - when planning to overtake, step harder on the accelerator. The City's CVT is smart enough to downshift and raise the revs, but if you want you can also flick the (-) shifter to ensure a downshift.
    During your overtake, just keep your foot on the pedal until you've completed the overtake and safely returned to your lane. Then you can release the accelerator and the car will upshift by itself and the revs will go down.
    There is no need to use the (+) shifter if you're in D as the car will upshift by itself once you let go of the accelerator.
    #8051
    Even in D, you can do the pass by timing your gas pedal application.
    Close the gap, match the speed and draft on the rear of the car in front, then sling shot to the passing lane. Shake & Bake just like Ricky Bobby.
    #8052
    Exactly. Around 70% of the time I'm able to overtake without having to go past 2500 rpm, even on two-lane provincial highways.
    Feb 2016
    #8053
    Thanks many many.
    Now i know where I went wrong. ☺
    #8054
    Yes, i do know that sir. Kaya ko din sinabi na the engine won't reach the redline eh. In that case, it will upshift by itself before it reaches that point.
    It will stay though in the same gear if the speed is steady, unlike when in drive, after engaging the paddle shifters, it will show what gear you are currently in for a while in which case you can do upshift/downshift and after remaining untouched for a couple of seconds, it will go back to display drive.
    #8055
    Sorry for that.
    I agreed / confirmed what you said hehe
    #8056
    Sorry for that.
    Hindi sir haha. Parehas lang po tayo ng observation regarding this.
    Sana lagyan na din ng honda ng paddle shifters yung e variants para may manual override na din.
    Feb 2016
    #8057
    Sabit ako. Iyak. Bros, ano kaya pede pantanggal sa ganyang scratch? Tapos may kasama pang yung yellow paint.
    #8058
    Change underchin? 🤔😂
    Feb 2016
    #8059
    You mean, the change the whole front skirt? Hehe. Ipon muna ako budget bro.. [emoji4]
    Change underchin? [emoji848][emoji23]
    #8060
    Modulo ba yan?
    Rubbing lang tanggal yan or para bawas eye sore.
    Makaka move on ka din.
2014 Honda City (Gen 4)
