Page 157 of 442 FirstFirst ... 57107147153154155156157158159160161167207257 ... LastLast
Results 3,121 to 3,140 of 8838
    Aug 2010
    #3121
    Quote Originally Posted by kabaong View Post
    Lots of time meron akong ganyan, yung friction ng disc brake rotor and brake pad ba? Usually kapag nabasa at kinalawang yung rotor, pero kung makinis naman ang rotor wala naman or minimal. I don't know kung normal lang din yun. Sana makahingi pa tayo ng feedbacks.
    Di ko din alam sir eh, actually di ko pa nakikita new car ko pauwi pa lang kasi ako from abroad, car is two weeks old. nung kinuha yung car and nagtravel sila last week wala namang sound, Sinabi lang sakin ni misis, nung inayos kasi ng cousin ko sa pagkaka park meron na ngang squeaking sound. Tumawag na kami kay SA and dadalin yung car sa casa this coming Saturday. Sana di seryoso yung issue.
    Jun 2014
    #3122
    Quote Originally Posted by ronmayajoan View Post
    Sir baka malamang yung brakes yun.. Ganyan talaga yan normal lang.
    Feb 2015
    #3123
    Front or rear breaks un squeaking sound? VX is all disk break? Pag disk break kc self adjust...un squeaking sound happens only when parked for a longer period at dahil naka engaged un hand break longer and normal lang na magka squeaking sound at first pero wala na yan after. I have the same issue with my 2015 suv and sa rear break may squeaking sound.
    Ask your dealer to clean the break pads and adjust.
    #3124
    Front = disk
    Rear = drum
    Last edited by cast_no_shadow; July 3rd, 2015 at 06:27 PM. Reason: It's disk not disc haha
    Oct 2009
    #3125
    Congrats!
    Ikaw pa lang yata ang naka VX+ with Navi dito. I'm curious sa new dashboard ng VX+. Ang alam ko lang na green light is yung ECON mode and "left and right" turn signal sa dashboard. Hope you can show us some interior/exterior look of the City VX+ with Navi with engine started.
    Congrats!
    Thanks. Here's the dashboard and navigation looks like on VX+ NAVI CVT. I took the picture while on parked mode so there's no fancy maps of resto, gas stations, etc.
    Quote Originally Posted by weszt View Post
    congrats welcome to the GM6. The green light is the fuel econ indicator. when it turns blue? means you ate stepping to much on he gas pedal.
    Thanks. It's not Econ Indicator sir eh. There's a separate icon for that. This is where the green light displays on the red circle, please refer to the image below. Not really sure what does it mean, basta minsan lalabas sya when I turned left/right or hitting the gas pedal.
    #3126
    Weszt is right.
    Green lit on is efficient driving, better fuel econ.
    Blue is bumibigat apak mo, mas malakas konsumo.
    Oct 2009
    #3127
    Weszt is right.
    I see. Thanks sir. After driving the new city for 3 straight days, I can say that the power is just right (for 1.5) even the car is full. Steering wheel is so soft and easy to maneuver, haven't tried to overtake yet though. Also, I noticed that the rear brake is drum? Cost cutting perhaps? I also get 9.3km/l for a 20 kilometers run on a city without any traffic.
    Aug 2009
    #3128
    Quote Originally Posted by Battlestar View Post
    on our gm6 the green/blue light is variable depending on the gas pedal. your gm6 looks different. the photo that you have overmarked with circle does not seem variable?
    #3129
    What do you mean it looks different? Di ko gets.
    May 2015
    #3130
    Wala na yung 3 buttons sa manibela? Yung accept/drop call?
    Aug 2009
    #3131
    diba yung satin pag nakaapak ka sa gas variable na prang circle na nagchange ung color ng eco light. blue or green. ung sa bago ngayon prang fix sya na blue or green lang hindi circle na variable
    Oct 2014
    #3132
    mga sirs, napansin ko lang dun sa automatic gear stick, paglipat from N to D and D to N, hindi na talaga kailangan ipress un nasa stick? malilipat mo sya agad? Pati din R to N to D, hindi na need ipress, from P to R lang sya naglalock at need ipress un nasa stick.
    normal po ba un? accidentally kasi nabangga ko un stick from neutral to drive ng hindi napress un nasa stick. tapos tnry ko na sa iba hindi nga lahat need ipress un stick.
    #3133
    Normal naman talaga yun basta pabalik to neutral no need to press the button sa stick.
    Pero park to reverse/drive
    Reverse/driver to park
    Neutral to reverse
    Reverse to drive
    Need to press it.
    Oct 2014
    #3134
    checked the manual. mukang ganun nga ang operation nya. normal lang pala.
    #3135
    What I'm thinking is how long kaya itatagal ng battery natin?
    May warranty ba yun?
    Oct 2014
    #3136
    Neutral to reverse
    Reverse to drive
    Need to press it.
    thanks!
    Neutral to reverse
    Reverse to drive
    Need to press it.
    thanks!
    Oct 2013
    #3137
    1 yr lang warranty ng battery natin. Nakalagay sa booklet. Learned it the hard way kasi nag-aasin yung battery terminal ko. Sabi nung 1yr PMS ko, defective battery daw. Eh 1yr and a few days na from date of purchase. Ayaw na nila palitan pero gumagana pa naman battery ko.
    Nov 2014
    #3138
    ok update mo kamo kng yung FC mo nagsuffer ng madami. hehe
    parang mas ok nga yan upgrade mo kasi ridecomfort pati handling ok.
    Natuloy yung roadtrip sir. From 15.1KM/L ko dati, naging 14.7KM/L na lang ako. but please note that yesterday, 4 na full size adult kami, yung dati, dalawa lang kami. I dont think naman na ganun kaaffected ung FC.
    BTW, very noticeable yung better handling especially sa downhill ng Lucban to Sta. Cruz.
    May 2015
    #3139
    Ano po difference ng Meguiars Quick Detailer at Quik Wax?
    Feb 2015
    #3140
    Mga sir ask ko lang, yung temp ba na nakikita sa right side na gauge ng VX yun yung temp ng engine or temp po yun outside the car? Naisip ko lang pano malalaman kung above the normal temp na yung engine... may indicator ba city pag maooverheat na engine? thanks!
2014 Honda City (Gen 4)
