Quote Originally Posted by patricksee View Post
first instinct of non casa mechanics is cleaning the throttle body or IACV. believe me, kahit ilang beses mo palinis or papalitan yan, di maaayos yung problem.
so far, i've read na yung flywheel nga yung culprit. there's a number of members here na naayos yung issue by replacing that. it costed them 18k. not sure about the control valve. try asking yung casa if they can replace the flywheel muna and see if it fixes the issue. and make sure na walang damaging effect pag yun lang ang palitan. baka kasi masisira lang ung flywheel eventually if hindi palitan na din ung control valve. you'll end up spending more.
as for my car, 2006 City 1.5 AT, minimal jerking/sliding clutch lang from full stop or backing up. Usually from full stop, nagddrop ng onti ung RPM, causing the car to shake a bit pero once may momentum na, ok na. Mas madalas pag reverse lalo na pag inclined yung road, talagang ramdam yung vibration then yung parang namamatay talaga yung makina. pero for now, i can live with it kasi hindi pa naman ganun kalala.
HTH!
yup... had that same exact experience... changed flywheel last october... 18 thou sa honda magallanes...yun daw talaga sakit nang honda cvt, better change it asap daw before it could do more damage sa transmission...
