Results 21 to 30 of 35
December 14th, 2006 10:03 AM #21
December 14th, 2006 12:12 PM #22
Ano ba naman talaga yang mga balita, nakaka-alarma at nakakatakot, buti na lang at may nagpost dito nyan...i'l do just the same w/ sir CVT and sir evs_13
Tsikot Member Rank 4
- 2,716
December 14th, 2006 12:57 PM #23
December 14th, 2006 02:28 PM #25
OT: may mga illegal pa bang drag race na nagyayari sa daang hari? dati kase parang nagugulat na lang ako may kumakaripas sa lumampas sakin e..
December 14th, 2006 03:12 PM #26
OT. sino kaya sa mga holdapers ang pinapahiga sa kalye? initiation kaya ito o turn by turn? pag inumpisahan ang pag sagasa sa kanila mahihirapan sila maka kuha ng volunteer.
December 14th, 2006 03:30 PM #27
Yep, if u keep going straight from Alabang n keep following that road, you end up on the Aguinaldo Highway. Right across from that exit is my Subdivision, Athena. Neways, When you are nearing the exit to the aguinaldo highway, the road isn't completely built yet..so it's like offroading kinda..so that means ur driving slow.. n its a great spot for holduppers n carnappers to get you at..since you're driving slow.
Just a couple months ago, I was driving through from the Aguinaldo highway to alabang and the road before daang hari itself there was a taxi, burnt to the crisp! Supposively a holdupper robbed th taxi driver, and then burnt the taxi, windows were gone, paint was burnt right off, the tires were burnt, it was a skeleton.
The most dangerous part of the cavite/alabang shortcut in my opinion is the road after daang hari (if u keep going straight) after the intersection, if ur coming from alabang, going to the aguinaldo highway. That road is pitch black, no lights at all. My car died there for about 2minutes, and i was scared as hell, i was looking around me to see if someone would jump out of the grass or shrubs. My suggestion is, Use highbeams when there are no oncoming vehicles at night so that u can see ahead of time if there's someone lying on the road. But the important thing is..DO NOT STOP. If you have to, run over that person that's lying there on the road. Be safe in that areaLast edited by KrisKros; December 14th, 2006 at 03:33 PM.
December 14th, 2006 06:46 PM #28
- Jan 1970
- 396
December 15th, 2006 10:31 AM #29i doubt very much kung may tangang papayag humiga sa gitna ng highway.. baka manequinn in clothes lang un. if you can, dont run over. mabuti kung manequinn lang, e minsan logs ang ginagamit ng mga yan. if the entire width of road is blocked, make a quick reverse, u-turn takes longer.
- 660
high idle RPM at engine start
