Meron na po kami or/cr. Just in time lg before umalis yung roro vessel na email sa akin ng agent ang or/cr.
Kapag PMS ba nilalagyan na din nila ng fluids yung car like sa coolant and brakes?
check lng. top off pag meron leak. normally during the 1st 3-5years wala dapat kelangan itop off...
"check fluids" is normally part of the pms check. but to actually add fluids... baka kayo mismo ang mahimatay kapag na-tanggap nyo ang bill for "topping off".
but once in a while, dahil tao din sila, ay nakakaligtaan nila... may tamad times din sila...
it's so easy for the car owner to do it himself. it would be almost negligent on his part, if he did not do something as basic as fluids check and top-off.
besides, it's much, much cheaper if owner does the topping-off, himself.
Hi everyone! Just wanna ask about changing gear smoothly. Okay lang ba na ipress yung gas while releasing the clutch as soon as I change the gear? Confuse talaga ako kasi everytime na magche-change gear ako, nagjejerk yung oto. [emoji22]
Rev matching on downshifts? Yes....
Rev matching - Drivingfast.net
Baka nare release mo yung clutch too early kaya ganyan. Or mababa yung apak mo sa clutch.
Sent from my LDN-LX2 using Tapatalk
Hindi ko din po magets eh. Dahan dahan naman yung pagrelease ko ng clutch then pag totally release saka ko lang inaapakan yung gas. First time driver kasi ako hehe
Pwede din maaga pa yung shift mo. Check mo yung tachometer kung nasa 2000-2500 rpm. Then shift up ka na. Sa una lang yan masasanay ka din
Sa pag shift okay naman sir, nasasakto ko naman sya ang problema ko lang lagi talaga nag jejerk pag nagrerelease na ko ng clutch
Both sir. Pero mostly sa upshift nangyayari. Kahit dahan dahan na yung pag bitaw ko ng clutch ganun pa din nangyayari.
May problema sa timing ng release ng clutch at apak sa accelerator kaya kumakadyot. Ideally kasi smooth dapat, sa footwork nga yan and very common sa mga newbie sa manual transmission. Dapat dahan dahan release ng clutch at the same time dahan dahan apak sa gas. Ang nangyayari kasi nabitawan mo na clutch at may konting delay ka sa apak sa gas, sa iba namamatayan pa ng makina. Practice lang yan at makukuha mo rin.
some cars are suave on clutch.
other cars are so abrupt on clutch.
you'll just have to keep practicing, until you get the hang of it.
walang sikreto diyan, except to keep practicing.
driving footwork is a learned skill.
