Results 21 to 40 of 43
    Sep 2006
    #21
    Just drop it about a foot above the latch. Pushing will dent the thin sheet metal.
    Though the manual tells you this, but I usually drop it lower than 1 foot,the closest na maglolock pa din sya.
    #22
    Yup, & should the latch not catch on drops from various heights, it's a sign it's LUBE time.[emoji4]
    Oct 2009
    #23
    depende sa stoper ng hood yan..pero ako ibaba ko lang saka kaunting diin nag lalacok na siya.sa civic at advie ko...
    pero dun sa ford focus ng bayaw ko dimo pwede ibaba lang basta saka idiin..hindi rin pwede ng mga ifeet.kailangan mga 2feet ang taas bago maglock..depende sa sasakyan din.kung saan siya lalapat at mag lalcok ng maganda
    #24
    On a classic VW Beetle, you grab the handle and slam the hood (trunk).
    ride with no damper, drop it like the others say.
    ride with damper takes a slight swing down but not to slam. takes a little practice to get just the right speed.
    yun dampers ng camry, sort of works pag pataas na. when going down it will still slam shut without going too hard though.
    #26
    Sa City need ibagsak, if you put it down gently then push it hindi siya mag lock.
    #27
    Quote Originally Posted by ;2945868
    we lower it down until it sits on the locking mechanism. then we give it a not-so-mild downward push.
    if we grab and slam, chances are, masusupalpal. that front hood has so much lateral movement.
    and it's not easy, untangling the mess that results if we miss the mark.
    #28
    Just drop it from the exact height.
    According to Daihatsu, they designed the latch and hood to be dropped (5-8inches). regular greasing is also necessary to keep the mechanism working
    Jan 2016
    #30
    Dropping the hood is more art than science.
    May 2018
    #31
    Quote Originally Posted by Kimchijiji View Post
    How do you close your hood?
    Siguro it depends on the model. Yung kotse, I'm dropping on at least less than a foot. But yung SUV, i can just lower it down and give a slight push downward, lalo na if bago.
    Jan 2016
    #32
    Slam it gently
    #33
    whatever minimum force it takes, to close it.
    it varies, even among the exactsame model units.
    Jul 2016
    #34
    If steel, slam hood para di ma dent pag diniinan lalo na may mga oto na sobra nipis hood.
    Pag carbon fibre hood, need diinan para sumara. No risk of dent naman sa CF.
    Apr 2012
    #35
    Slam it gently
    same here papi
    Jan 2013
    #36
    Not really slam but just let gravity do its work. Leave about a foot or foot and a half and then release holding it. Usually does the trick.
    But yeah, depends on the vehicle. Meron kailangan may pwersa talaga. Meron halos ilapat mo lang pwede na.
    Sent from my ONEPLUS A3000 using Tapatalk
    Sep 2006
    #37
    Ang taas na yata foot and a half.
    Apr 2006
    #38
    dati i just fit the hood and push it - on 2 (ek and gen1 crv) cars. no problems.
    but when we picked up a new innova at the casa and SA saw me fit and push the hood, told me it would be better to drop it from around a foot.
    looking back, it is because it seems newer cars have thinner hoods. baka nga mag-dent. while sa older cars, the hoods are thick. no danger of denting it pag diniinan.
    nowadays, i just drop it. gently.
    Jan 2016
    #39
    Slam it gently
    6 inch drop, does it for me.. parang hampas kapatid lang
    Aug 2017
    #40
    Just doing in between 6 to 12 inches.paswabe effect lang...hehe
    Sent from my iPhone X using Tapatalk
Slamming hood or putting it down gently?
