Page 1 of 3 123 LastLast
Results 1 to 20 of 43
    Jan 2017
    How do you close your hood?
    Mar 2017
    I let it down gently, then a little push to lock it in.
    Quote Originally Posted by Kimchijiji View Post
    Just drop it about a foot above the latch. Pushing will dent the thin sheet metal.
    Aug 2004
    Lower it to about a foot off the lock then drop. Hoods nowadays are built from thin sheet metal and a misplaced hand pushing down the hood might dent it.
    Mar 2017
    Good to know! I learned something useful today
    This is what I do as well
    Mar 2017
    I've been doing it wrong all this time! Buti at wala pang damage yung hood ko.
    Quote Originally Posted by AllenR View Post
    Criminal minds should leave no prints.[emoji16]
    Dec 2017
    Same thing here, I just drop it. Newer cars are so thin, You can actually "feel" it whenever​ you wipe it clean. Older cars are thicker, so are heavier.
    Sometimes I say, I like the older ones. Not just thicker metals, thicker paints too.
    Mar 2017
    I like the way you think, sir!
    Gentle gentle drop.
    For hoods with a damper, you have to push it down from a few inches high with a little force.
    Hehe...Old excesses weren't eco-friendly.[emoji17]
    drop it like its hot
    Feb 2014
    w/ some experimentation you can determine the optimum height of the drop. so that you don't drop from an excessive height and thus place too much shock on the components. for most cars it's just around one hand span
    ride with no damper, drop it like the others say.
    ride with damper takes a slight swing down but not to slam. takes a little practice to get just the right speed.
    Aug 2004
    Like some hatchback doors
    Nov 2014
    Yup same thoughts. My car's hood and hatchback door both close properly when you just "drop" it from about a hand span above. If you slam the rear door, it will bounce back up and if you drop the hood from too little a height, it won't latch.
    The Fiesta's hood is a bit heavy so I cannot just drop it or else it's a loud bang. I let it down gently then drop it with only a few inches left. The FXT's hood has a hydraulic hinge so pulling it up and down is a bit controlled.
    it depends, sir.
    some car's hoods lock in place with only a small downward push, after gently setting it down.
    other cars need to have their hoods dropped from about 6 inches above.
    my car had been involved in a frontal before. i have to drop her hood from 1 foot to 1 1/2 feet up. it wakes up the dead, but it's the only way to lock it down. one of these days, kukutingtingin ko siya...
    i have all three.
    Quote Originally Posted by kai s. View Post
    lalo na nung di pa na adjust kai no? ^_^
Slamming hood or putting it down gently?
