Results 11 to 20 of 27
    Nag eenjoy lang ako panoorin videos ni Engineering Explained first few minutes. Nabobore na ako kapag tumatagal. [emoji23]
    sarap pampatulog 😅😅😅
    Mar 2004
    He explains too much ... like an engineer ...
    sa situation dito pinas....nakakangawit naman sa paa yung laging nakaapak sa brake.....
    so pinakamaganda na yung iangat handbrake....
    ako pag matagal-tagal stoplight inuneutral ko talaga.....
    importante kung sa comfortable katawan ko....
    nakakangawit talaga matic....
    Sep 2006
    Haha. I see what you did there.
    May 2009
    I say both have advantage and disadvantages. Its true bibilis friction band wear but not shifting to N will also hasten wear on your brakes. Which one is cheaper to maintain?
    pag panay ang shift mo from D to N to D mapupudpod yung planetary gear friction band. so the best practice is to keep it in D and just use the brakes.
    Quote Originally Posted by granro01 View Post
    cheaper to repair ang brakes palit brake pads ka lang.
    Mar 2004
    Brakes are definitely cheaper to access and repair ... don't think doing so will wear out the brakes that much ... after all you are just holding the vehicle in stop position ...
    Sep 2006
    I think I need to change my driving style dahil dito
    I'll just engage my handbrake then.
    Sent from my SM-T705 using Tsikot Forums mobile app
Proper way to slow crawl in traffic using conventional automatic and CVT transmission
