Results 1 to 10 of 14
August 2nd, 2007 11:06 PM #1
Hi! Got problem with my Mitsu Galant Super Saloon 96 model. kakabili ko lng sya 2 months ago, nung pina change oil ko sya, npansin ng mechanic na ang taas dw ng RPM ko. so binabaan nya. after lng ng mga 1 month siguro, ngka problema na. kumakadyot kadyot sya pag bumabagal takbo ko or kung pahinto sya, hanggang s tumirik na ako. pina check ko sya s talyer, palyado dw mkina ko, pro mas mgnda dw kng pa check ko s service center ng mitsubishi na computerized dw. ano kaya posibleng dhilan ng problema ng auto ko? mga mgkano kya gastos? ska san kya ako pwedeng mgpagwa na mura lng? ung bandang cainta or mandaluyong sana.. nagtanong kc ako s mitsubishi, bka idle dw problema dey want to see my car first kaya dalin ko dw muna.. pro kung idle dw prob estimate mga 20k dw mgagastos ko! kaya na-shocked tlga ko! ano ba ung idle? la kc tlga ako alam s kotse. hope ul give me advices. I badly need it right now.. prang ayoko n tuloy magka kotse.. hehe! thanks in advance!
August 3rd, 2007 09:56 AM #3
after two weeks, we solved my sister's palyadong makina problem last weekend.
here is what we did....
a. changed spark plugs (ganun pa din)
b. timing (ganun pa din)
c. changed fuel filter (ganun pa din)
then we went down to the following theories:
a. fuel pump, which is unlikely... walang tagas.
b. injector cleaning
c. hi tension wire
when i borrowed my friend's extra hiten wire and put it dun sa oto ni sister, nawala yung palya....
just my experience... you might be able to pick-out something from this.
August 3rd, 2007 10:05 AM #4
Mahirap na ang trial and error method.
Get a complete computer diagnostic at mitsubishi casa but don't have it repaired there.
Purchase the diagnosed faulty party (surplus if on a budget) and have it repaired by a trusted mechanic outside the casa.
August 5th, 2007 11:11 AM #6
Sir share ko lang experience ko dyan.. Same thing happened to my car when I first bought it 91' A/T Galant SS. My friend mechanic advise me to drain my fuel tank and replace Fuel filter dahil my tubig na sa loob kaya pag medyo nagmemenor ka eh parang mamamatay yung makina even totally mag shut down. After that ok na .. Ask ko lang Sir A/T ba yang Galant mo? ...
- Jul 2007
- 3
August 5th, 2007 01:24 PM #7sir happy, what do you mean "extra hiten wire". coz i'm also experiencing with my EG right now. I already change oil, tuning it. Last week i change the fuel filter medyo nawala konte yung palya but then namamatay din sya. Yung case ng EG ko is when I use it & then for ex. nag park ako for 5 mins or nag gas ako.Mag iistart sya, tapos mamatay. Then puro redondo na lng. I have to wait mga 5-10 mins para mag start sya ulet. My mechanic advised me to change the fuel pump & clean the fuel tank. Maybe nxt week ko na lng ppagawa.Canvass muna. I'll appreciate your advices. Thanks in future.
August 5th, 2007 02:12 PM #8
August 6th, 2007 07:57 AM #9
- Jul 2007
- 3
Kwento ng katrabaho ko, meron daw sya officemate dati na Italiano na tinanong daw bakit...
Traffic!
