Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
    Quote Originally Posted by nuformz View Post
    Sir happy, any advice for my EG problem? Tnx.
    ang hesitation during acceleration eh caused by several problems. among of which [SIZE=2]may be due to a vacuum leak, but it can also be caused by dirty fuel injectors, a weak fuel pump (low fuel pressure) or a faulty fuel pressure regulator. It can also be caused my ignition misfire due to worn or fouled spark plugs, bad spark plug wires (or high tension wires) or weak ignition coil.
    for your EG, talagang mahirap mag isolate nyang mga yan eh. for sure, you have to take it to a mechanic (dalahin mo na kay speedyfix yan), para talagang ma-isolate ang problem. mahirap kasi kung DIY ang isolation, baka kasi palit ka ng palit ng parts, pero hindi pala yun ang sira.
    yung sa sister ko as mentioned above, talagang na-chambahan namin i-isolate yung hi tension wires dahil, yun ang pwede kong gawin, dahil may extra nga akong nakuhang hi-ten wires. pero ang next step namin talaga nun, kung talagang hindi pa ma-isolate is for her to bring the car to a mechanic na.
    [/SIZE]
    for misfiring, please see this link... very informative...
    http://www.aa1car.com/random-misfire/
    Nov 2006
    hi! pina top overhaul ko n ung kotse ko. pinapapalitan narin nila ung lhat n sparkplugs kc d dw gumgana ung isa. pati thermostat b un.. pinapalitan narin. un kc ang advice ng mechanic. 6800 ang siningil sakin. reasonable b un? mgkno b tlga pa top overhaul? I was about to bring my car sna knina s Speedyfix gaya ng sbi nyo, kso d nko umabot. Nag overheat ako tpos tumirik. so no choice ako kundi ipa check s pinakamalapit n talyer. hay.. sna nman mtapos na tong problem ko, bukas mkukuha ko n ung kotse. d b ako ndaya s presyo? ska pano ko b malalaman kung kelan n dpat ipa top overhaul ung sasakyan? thanks!
    Feb 2009
    sir happy, what do you mean "extra hiten wire". coz i'm also experiencing with my EG right now. I already change oil, tuning it. Last week i change the fuel filter medyo nawala konte yung palya but then namamatay din sya. Yung case ng EG ko is when I use it & then for ex. nag park ako for 5 mins or nag gas ako.Mag iistart sya, tapos mamatay. Then puro redondo na lng. I have to wait mga 5-10 mins para mag start sya ulet. My mechanic advised me to change the fuel pump & clean the fuel tank. Maybe nxt week ko na lng ppagawa.Canvass muna. I'll appreciate your advices. Thanks in future.
    hiten wire mean high tension wire, these are the wires connecting distributor to spark plug
palyado makina? need advice! please!
