Results 1 to 14 of 14
    Nov 2006
    Hi! Got problem with my Mitsu Galant Super Saloon 96 model. kakabili ko lng sya 2 months ago, nung pina change oil ko sya, npansin ng mechanic na ang taas dw ng RPM ko. so binabaan nya. after lng ng mga 1 month siguro, ngka problema na. kumakadyot kadyot sya pag bumabagal takbo ko or kung pahinto sya, hanggang s tumirik na ako. pina check ko sya s talyer, palyado dw mkina ko, pro mas mgnda dw kng pa check ko s service center ng mitsubishi na computerized dw. ano kaya posibleng dhilan ng problema ng auto ko? mga mgkano kya gastos? ska san kya ako pwedeng mgpagwa na mura lng? ung bandang cainta or mandaluyong sana.. nagtanong kc ako s mitsubishi, bka idle dw problema dey want to see my car first kaya dalin ko dw muna.. pro kung idle dw prob estimate mga 20k dw mgagastos ko! kaya na-shocked tlga ko! ano ba ung idle? la kc tlga ako alam s kotse. hope ul give me advices. I badly need it right now.. prang ayoko n tuloy magka kotse.. hehe! thanks in advance!
    Aug 2003
    dalhin mo nalang sa speedyfix.
    along shaw lang sila
    after two weeks, we solved my sister's palyadong makina problem last weekend.
    here is what we did....
    a. changed spark plugs (ganun pa din)
    b. timing (ganun pa din)
    c. changed fuel filter (ganun pa din)
    then we went down to the following theories:
    a. fuel pump, which is unlikely... walang tagas.
    b. injector cleaning
    c. hi tension wire
    when i borrowed my friend's extra hiten wire and put it dun sa oto ni sister, nawala yung palya....
    just my experience... you might be able to pick-out something from this.
    Oct 2003
    Mahirap na ang trial and error method.
    Get a complete computer diagnostic at mitsubishi casa but don't have it repaired there.
    Purchase the diagnosed faulty party (surplus if on a budget) and have it repaired by a trusted mechanic outside the casa.
    Nov 2006
    guys, thanks s advices ha? hay..
    May 2007
    Quote Originally Posted by viepink View Post
    Sir share ko lang experience ko dyan.. Same thing happened to my car when I first bought it 91' A/T Galant SS. My friend mechanic advise me to drain my fuel tank and replace Fuel filter dahil my tubig na sa loob kaya pag medyo nagmemenor ka eh parang mamamatay yung makina even totally mag shut down. After that ok na .. Ask ko lang Sir A/T ba yang Galant mo? ...
    sir happy, what do you mean "extra hiten wire". coz i'm also experiencing with my EG right now. I already change oil, tuning it. Last week i change the fuel filter medyo nawala konte yung palya but then namamatay din sya. Yung case ng EG ko is when I use it & then for ex. nag park ako for 5 mins or nag gas ako.Mag iistart sya, tapos mamatay. Then puro redondo na lng. I have to wait mga 5-10 mins para mag start sya ulet. My mechanic advised me to change the fuel pump & clean the fuel tank. Maybe nxt week ko na lng ppagawa.Canvass muna. I'll appreciate your advices. Thanks in future.
    Nov 2006
    Quote Originally Posted by nirdle03 View Post
    yup, A/t galant ko. cge yan ang ipapagawa ko sa daddy ko. sna nga fuel filter lng prob sna d malaki mgastos... huhuhu! anyway, thanks s advice ha?
    Quote Originally Posted by nuformz View Post
    it simply means may nahiraman ako ng extrang high tension wire.
    Sir happy, any advice for my EG problem? Tnx.
    ang hesitation during acceleration eh caused by several problems. among of which [SIZE=2]may be due to a vacuum leak, but it can also be caused by dirty fuel injectors, a weak fuel pump (low fuel pressure) or a faulty fuel pressure regulator. It can also be caused my ignition misfire due to worn or fouled spark plugs, bad spark plug wires (or high tension wires) or weak ignition coil.
    for your EG, talagang mahirap mag isolate nyang mga yan eh. for sure, you have to take it to a mechanic (dalahin mo na kay speedyfix yan), para talagang ma-isolate ang problem. mahirap kasi kung DIY ang isolation, baka kasi palit ka ng palit ng parts, pero hindi pala yun ang sira.
    yung sa sister ko as mentioned above, talagang na-chambahan namin i-isolate yung hi tension wires dahil, yun ang pwede kong gawin, dahil may extra nga akong nakuhang hi-ten wires. pero ang next step namin talaga nun, kung talagang hindi pa ma-isolate is for her to bring the car to a mechanic na.
    [/SIZE]
    for misfiring, please see this link... very informative...
    http://www.aa1car.com/random-misfire/
    Nov 2006
    hi! pina top overhaul ko n ung kotse ko. pinapapalitan narin nila ung lhat n sparkplugs kc d dw gumgana ung isa. pati thermostat b un.. pinapalitan narin. un kc ang advice ng mechanic. 6800 ang siningil sakin. reasonable b un? mgkno b tlga pa top overhaul? I was about to bring my car sna knina s Speedyfix gaya ng sbi nyo, kso d nko umabot. Nag overheat ako tpos tumirik. so no choice ako kundi ipa check s pinakamalapit n talyer. hay.. sna nman mtapos na tong problem ko, bukas mkukuha ko n ung kotse. d b ako ndaya s presyo? ska pano ko b malalaman kung kelan n dpat ipa top overhaul ung sasakyan? thanks!
    Feb 2009
    hiten wire mean high tension wire, these are the wires connecting distributor to spark plug
palyado makina? need advice! please!
