eto din, onli in da pilipins.. :mrgreen:
>If you are ever in the need to drive on the streets of
>Manila the following rules may help you get to your
>destination in one piece.
>THE FILIPINO DRIVER GREETING:
>When greeting a Filipino driver, slowly lower your
>window and be prepared to greet the driver with, 'Tang
>'namo, bobo!" However, if you have been already
>addressed by a fellow driver, reply with a joyful,
>"'Tang'namo rin, *#%$!"
>ON TURN SIGNALS:
>If a driver in another lane turns on the turn signal,
>do not let him go into your lane. In fact, press the
>accelerator and start driving right next to him/her.
>The fellow driver will probably greet you and you
>already know what to do.
>ON TRAFFIC LIGHTS:
>These amusing artifacts hang from intersections for no
>apparent reason. Sometimes you will see drivers stop
>to see the colors change on these lights (a
>fascinating experience). Government officials
>(specifically police) believe that each color stands
>observation I have determined the following
>instructions for each color:
>Yellow light - accelerate your car as much as you can.
>Red light - this light gives permission to the next
>five to six cars to go through.
>Green light - reduce speed and wait for the five to
>six cars passing through their respective red lights.
>Little-known-fact: Time to start honking your horn, as
>soon as the light turns green = 1.5 seconds.
>ON CHANGING LANES:
>Changing lanes has been elevated to an art form in the
>Philippines. First of all, no matter what you do,
>never ever turn on your turn signal, otherwise you'll
>stimulate the reaction described above. Second, swerve
>your car uncontrollably to the lane you want to
>hange, preferably if you end up within inches of a
>car in that lane. At this point a greeting from
>theother driver may be in order. To perfect your
>change of lanes, reduce the speed of your car
>dramatically in a matter of seconds and you will see
>an action-packed reaction from the car behind you.
>ON TRAFFIC JAMS:
>Traffic Jams are teeming with fun filled activities
>such as:
>1. Honking your horn rhythmically.
>2. Putting on make-up (usually female drivers only).
>3. Nose-pickers sightseeing (not to be confused with
>people who scratch their brains through their nose).
>4. Reducing speed to watch whatever is causing the
>traffic jam. Add excitement by trying to see if you
>know the parties involved.
>(Note: Every Filipino driver is obliged to dothis.)
>5. Losing weight by sweating like a pig as a result of
>a lack of air conditioning.
>6. Greeting other drivers.
>7. Practicing lane changing.
>8. Playing the game: Let's see how close I can get to
>you before rear- ending you.
>ON PEDESTRIANS:
>These individuals are an annoyance to the Filipino
>driver. If you see pedestrians in your way,
>accelerate your car to let them know who's the boss.If
>you are at an intersection, let the pedestrians know
>you want to proceed by accelerating your car and
>honking at the last possible moment.
>ON SOCIAL SITUATIONS:
>Bumping into a friend while driving (not to be
>takenliterally) is a joyful occasion. Drivers should
>reduce speed and stop their cars in the middle of the
>street and chit chat. What about other drivers? Well,
>they can wait.
>Bottleneck Formation - To accomplish this type of
>driving, cars must block all lanes by driving at the
>same speed and side by side (to avoid other cars to
>pass). It is important to drive at a speed at least 20
>mph below the speed limit.
>The Three-Lane-Change - This movement requires a lotof
>precision and creativity. It should be done around the
>highest number of cars possible and in a matter of
>seconds to create what others may refer to as
>widespread panic.
>HERE'S ANOTHER RULE FOR DRIVING IN THE PHILIPPINES.
>When the lanes going in your direction are jammed with
>cars, try using the lanes from the oncoming traffic.
>They are probably not occupied anyway because the
>oncoming cars are stuck as well. How many of the other
>direction's lanes should you occupy? As long as there
>are lanes from the other direction to occupy, go ahead
>and take more lanes. This move is sure to elicit
>previously mentioned greetings from drivers of the
>oncoming cars (and some have been known to get down
>from their cars to personally deliver the greeting to
>the out of lane driver). 9 out of 10 times it's sure
>to make the traffic worse but then, hey, there's that
>1 in 10 chance that you might actually get through
>sooner than all those law-abiding losers. Filipino
>drivers think that 1 in 10 chance is reason enough to
>risk their life and limb and being profusely greeted
>(besides, you can always turn up the windows and
>pretend that you don't hear the greeting from the
>other drivers).
