Results 11 to 20 of 41
November 27th, 2024 10:04 AM #11
Also thought this was the case before ... but they did a test and fuel consumption is the same when in Neutral or Drive at a stop light ... when you search online, most will advise leaving it in Drive and not shift to Neutral ... trying to understand why this is the case ... just doesn't make sense ... might have something to do with auto brake hold being more available nowadays ... for practical and safety reasons, still shifting to Neutral at a stop light for safety ...
Maybe it's also due to the new generation drivers shifting to Neutral every time the vehicle stops ...
November 27th, 2024 10:40 AM #13
November 27th, 2024 10:43 AM #14
Oh, but they do. Though not that significant, but they do add up.
I've done this experiment on two vehicles.... my old Civic 1.8 and my Innova 2.8 Diesel.
Civic 1.8 idle fuel consumption (Liters per Hour or LPH) when in Neutral vs Drive and with the A/C compressor engaged and disengaged:
Innova 2.8 Diesel idle fuel consumption when in Neutral vs Drive:
Neutral: 0.7 LPH
Drive: 1.0 LPH
So in both cars, gasoline and Diesel, the added fuel consumption is roughly 30% when you leave it on Drive when idling.
- Nov 2019
- 1,426
November 27th, 2024 10:50 AM #15
- 54,232
November 27th, 2024 11:10 AM #16as someones already explained,
idle at D, with the brakes engaged, and the engine crankshaft rotates against a resistance. the brakes are also stressed.
idle in N, and the crankshaft rotates against a significantly lower resistance, and the breaks are not stressed so much.
November 27th, 2024 11:13 AM #17
This summarizes it well ... to add to this ... if you see the stop light just turn from green to red, then shift to Neutral ... when there is already a long line waiting at a stop light, leave it in Drive since chances are that the light is about to turn green ... unless there's a gridlock ...
From Drive, foot brake then Neutral then parking (hand) brake then release foot brake ... but do not shift to Park ...Last edited by Walter; November 27th, 2024 at 11:16 AM.
November 27th, 2024 11:28 AM #18
just sharing...
ako din, I will always put the vehicle in neutral (then handbrake) kapag matagal akong maghihintay.
pero with our Zenix...
naka-pila ako to enter the parking (it was full) kaya I decided to put it in "N" tapos handbrake ako... when the engine was about to start, nag notify yung car to put the car in D... personally, di ko maintindihan why that happened... never experienced that before kapag nasa P yung shifter ko
November 27th, 2024 11:56 AM #19
- Jul 2011
- 72
November 27th, 2024 12:12 PM #20
Oh yeah you're right! I think I'll re-watch the film tonight
2009 Lotus Esprit
