Results 1 to 10 of 41
- Jan 2007
- 2,584
November 26th, 2024 05:08 PM #1
tl;dw:
A Toyota Master Diagnostic Technician shares 7 Things you should never do to an automatic transmission.
Folks save your expensive transmission. Never do this to your automatic transmission!
In this video I will go over 7 things you should. never do to an automatic transmission.
First Protect the parking pawl! The parking pawl is a small metal part inside the transmission that locks it when you're in park. Slamming your car into park before coming to a complete stop or letting the weight of the car rest on it is a sure way of risking damage to the parking pawl.
Third Warm up your transmission before take off. Wait WHAT? Most people warm up their engine but in reality modern engines don't need much warming up. It's your transmission that needs a little bit of warm up to get going well.
Fourth Don't use your transmission as a brake! Downshifting intentionally to slow down the car puts extra load on the transmission. Most people do this to save their brakes which cost a fraction of what the transmission costs.
Fifth In snow driving if you get stuck, Don't just rev up the engine and let the wheels spin. This puts a tremendous load on your transmission.
Sixth Protect your Shifter! Accidents happen where we spill things over the shifter, But don't just leave it be. Clean the shifter and dry it up inside to prevent further issues.
Last but not least Don't put your car in neutral in short stops like traffic lights.
There's a few items here that it turns out I'm not careful enough about, like putting it in park too quickly when in a hurry, or putting it in neutral during short stops (didn't know this causes engagement/disengagement of the clutch that causes wear).
- Jan 2007
- 2,584
November 26th, 2024 05:23 PM #2*Mods: Sorry if I posted this in the wrong section. Just realized The Workshop / Transmission Talk will be a better fit.
November 26th, 2024 05:26 PM #3
- 54,202
November 26th, 2024 05:40 PM #4in my opinion, keeping the AT on D, and stepping on the brakes, while waiting for the red to turn green, is potentially dangerous.
"isang langaw lang yan sa loob nang kotse, can make the driver lose concentration and release the brake pedal..."
an online mechanic's program in youtube recommends D + footbrake, however...
November 26th, 2024 05:50 PM #5
1. Parking pawl - I generally agree... but these are not exactly as fragile as people think they are. However, it will break if it's frequently abused
2. Replace the ATF - I totally agree. Lifetime fluids are a myth to anyone who likes to keep their cars trouble-free
3. Warming up the A/T - Not really applicable in our tropical weather. But don't thrash it either
4. Engine braking - As he says, do it conservatively to regulate speed and prevent brake fade on long downhill roads. It's a safety issue not to overheat the brakes. However, don't do it to slow down the vehicle every time you need to stop. Though, most modern A/Ts would apply light engine braking when you step on or just lightly tap on the brakes. Helps with fuel economy
5. Driving in snow - Again, not applicable to us. The closest equivalent scenario would be doing donuts or getting unstuck on sand. Don't force it or risk overheating the A/T
6. Protect the shifter from spills, physical abuse, etc. - This is self-explanatory...
7. Unnecessary shifting between Drive and Neutral - Again, moderation is key. It's ok to shift to Neutral (+ handbrake) when in a particularly long stop. But don't do it every time you come to a stopLast edited by oj88; November 26th, 2024 at 06:06 PM.
November 26th, 2024 08:05 PM #7
coincidentally, i also watched this vid earlier today.
i guess the algorithms of every tsikoteer sort of mirrors each other.
- Nov 2019
- 1,406
November 26th, 2024 10:03 PM #8That's the purpose of auto-hold feature in some vehicles na naka EPB.
I am always using the auto-hold feature.
If sa traditional hand-brake naman, no choice but to switch to P (switch to N+handbrake before going to P) if mataas pa time ng stop signal for safety reason.
If sa N daw kase, umiikot pa yung gear ng transmission mo na naka freewheel rotation.
Kaya daw not recommended to switch to N if long stop.
Mas better pa raw naka D dahil naka lock yung gear so hindi siya moving as long as nakatapak sa brake/EPB.
November 27th, 2024 09:11 AM #9
Use P only when parking ... not a smart idea to use when at a stop light ... there's a reason it's labeled as P = Park ...
November 27th, 2024 09:58 AM #10
Wrong. Neutral is where the A/T is most "relaxed". Everything is free-wheeling, including the torque converter.
When in Drive and with the brakes applied and/or auto-hold activated, the torque converter is engaged, adding load to the system. Specifically, the impeller (engine side) is constantly trying to transfer power by pumping ATF to the turbine (transmission side), which is held stationary due to the brakes being applied. This constant churning of the ATF (stuck between a hard place and a rock) can raise the ATF temp somewhat. And because there's that viscous interface in the torque converter adding load to the engine, it increases fuel consumption.
Notice how the idle sags ever so slightly when you shift from Neutral to Drive? The torque converter is engaging and trying to move the car, but the brakes (or auto-hold) is preventing that from happening. This is like half-engaging the clutch while in 1st gear on an M/T with the brakes applied.
So, feel free to shift to Neutral during long stops. You're doing your A/T, engine, and yourself a favor.Last edited by oj88; November 27th, 2024 at 10:00 AM.
Found one on Marketplace : Log into Facebook
Mitsubishi Philippines
