well, if you want a quick fix on the performance side of your car, you can have a nitrous oxide kit installed. That should be good enough to boost your 1.6L engine's output from 110hp to 150hp. You'll probably need to upgrade the clutch to a stage 1 kit if you plan to race often enough.
Also better tires so you will have traction during launch. My car's tires were slipping until 3rd gear when I got the bolt-on turbo kit installed.
Anyway, the level of mods will depend on what you want to do with the car.
